Intake manifold comparison
Old Jun 21, 2007 | 12:29 AM
2000Z28ls1's Avatar
Default Intake manifold comparison
I have been looking around the site for the better part of an hour and I havnt found anything good on intake manifolds I was wondering which would be the best I have looked around and found a BBK one with a 80mm TB or the Fast with a 90mm TB or a LS6 or a Z06 manifold anyone have info on these or any good advice on which on to pick I have a 2000 Z28
Old Jun 21, 2007 | 01:30 AM
bww3588's Avatar
LS6 unless you have a major cam in it. best bang for the buck.
Old Jun 21, 2007 | 09:56 AM
senicalj4579's Avatar
ls6 intake imo. Everything else is just to damn expensive. I picked up mine in the fs section for 300 brand spankin new right out of the gm box from a guy. Ls6 all the way
Old Jun 21, 2007 | 01:03 PM
2000Z28ls1's Avatar
alright thanks guys while were on the subject how do I go about porting my TB and do I have to go about re tuning anything?
Old Jun 21, 2007 | 03:07 PM
SmallTires's Avatar
Get the LS6 intake, probably the best budget intake out there at the moment. As far as adding a ported throttle body on top of this, it shouldn't require a retune, but to get the maximum benefit out of any mod dealing with the engine it can be very beneficial to do so.
Old Jun 21, 2007 | 03:43 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The LS6 intake and the Z06 intake are the same thing. Unless you are doing a heads/cam swap then stick the LS6
Old Jun 21, 2007 | 07:43 PM
JEB99TA's Avatar
Do it once and be done with it if your budget allows it. Ported FAST 90 ... dpends on how radical you end up going with modding your car.
Old Jun 22, 2007 | 02:15 AM
bww3588's Avatar
yes, if you plan to do wild cam and heads, go ahead with the FAST/NW 90/90, but if you plan to stay mild for any period of time, stay with an LS6. the 90/90 will show minimal gains on a stock motor and might actully hurt performance because it will be overwhelming the cylnders.
Old Jun 22, 2007 | 10:20 AM
jmm98LS1's Avatar
LSx intake comparison:
http://www.tpis.com/plog/index.php?o...Id=14&blogId=1
I'd go with the ls6 unless you're going with a monster h/c combo or big cubes.
Old Jun 26, 2007 | 10:14 AM
radkon's Avatar
http://www.vetteweb.com/tech/vemp_06...o_testing.html
For most setups the LS6 is enough.
Old Jun 26, 2007 | 02:22 PM
wannafbody's Avatar
has anyone dynoed a BBK intake?
