somthing every 98 ls1 owner should do....
Old Jun 28, 2007 | 07:23 AM
  #41
peterock98's Avatar
Why not turn off the knock sensors.I was told as lost as I use 93 octane it will be fine.My car has 89000 miles on it and I drive it to and from work & so far so good..with the sensors out of the pcm
Old Jun 28, 2007 | 11:06 AM
  #42
SladeX's Avatar
I don't think my knock sensors are a problem considering I'm managing 109 trap speeds in 90 degree temps where bone stock I was barely touching 100mph in the same temps. This is with my car spinning 1st and most of 2nd now on 315 tires and no tread...
I wouldn't touch them unless your car shows obvious signs of power loss either on a dyno or at the track.
Old Jun 28, 2007 | 12:13 PM
  #43
kaos_'s Avatar
would bad knock sensors allow any kinda noise to be made? i'm hearing a very light put put put sound coming from what seems to be the intake area. my car is a 98 but has the LS6 intake on.
Old Jun 28, 2007 | 03:41 PM
  #44
bad6as's Avatar
ok ive been trying to get the rite part numbers for the new updated sensors and the new harness, i have 4-5 different # for the sensors and 3 diff numbers for the harness. and i was told the harnes had to be spliced in. some one set this stright
Old Jun 28, 2007 | 04:19 PM
  #45
GR33N GoblinM6's Avatar
how do you find out when yours was made?
Old Jun 28, 2007 | 06:06 PM
  #46
Black_Bird's Avatar
Door sticker.
Old Jun 28, 2007 | 06:39 PM
  #47
ez98ls1's Avatar
Updated sensors: 12589867 x2
Updated harness: 12601822 x1
around $130.00 delivered.
This is what I ordered from SDPC2000.com. These are the correct and updated sensors.
Old Jun 29, 2007 | 04:36 PM
  #48
bad6as's Avatar
does the harness plug in or does it to cut and spliced in?
Old Jun 29, 2007 | 10:32 PM
  #49
98SS1LWEE's Avatar
Harness? Cut and sPLICE, OR pLUG?
Old Jun 30, 2007 | 01:32 PM
  #50
bad6as's Avatar
i was told the the new harness for the new sensors had to be spliced in the engine harness
but i was also told it plugs in to the engine harness.
so to the ones who have done this was it a plug in or did you cut the old off and wire up the new one?
Old Jun 30, 2007 | 02:48 PM
  #51
brandonppr's Avatar
If you have the new ones they will have the part number stamped on them and the white part looks like these:
GM p/n 12589867
And if you have the old ones, they look like this:
GM p/n 10456222
Old Jun 30, 2007 | 03:29 PM
  #52
bad6as's Avatar
can you take a picture of the wiring harness?
Old Jun 30, 2007 | 04:15 PM
  #53
98SS1LWEE's Avatar
CRAP! i do have the old ones, and just put the metal intake on, gonna suck pulling it again, wasn't the easiest to set right
Old Jun 30, 2007 | 04:21 PM
  #54
bww3588's Avatar
whats your build date 98SS1LWEE? i would guess it would be safe to assume that any car made prior to his car will have the old sensors?
Old Jun 30, 2007 | 04:23 PM
  #55
5_02ls1's Avatar
Have fun on those gaskets...^^^^lol
the harness plugs in...I have no idea why you would wanna cut it......
Old Jun 30, 2007 | 04:29 PM
  #56
98SS1LWEE's Avatar
Yeah, mine was honestly a late build, so i have to say, i don't think there are a ton of 98's with the new ones, mine was built in 07/98! Went to SLP in Mid July
Old Jun 30, 2007 | 04:53 PM
  #57
bww3588's Avatar
idk, one dude on here says his was built 12/98.
Old Jun 30, 2007 | 10:46 PM
  #58
brandonppr's Avatar
I don't have a pic of the harness. I might can get one of the new style later.
Old Jun 30, 2007 | 10:48 PM
  #59
brandonppr's Avatar
Well I found a pic of the new style notice the end conectors how there made:
Here is another pic of the new style knock sensors:
another pic of the new style:
another New style harness and sensor:
OLD style sensor:
Old Jul 1, 2007 | 03:01 PM
  #60
JGA's Avatar
JGA
Originally Posted by PAGregSS
Yes, they changed to the "new" knock sensors during production. My car was built late in the run and it has the new style knock sensors and harness. Never had a problem with knock or false knock.
Hi
Any estimate of early vs late run dates? As I am just about to do an intake swap I should check my date code. Should I take mid 97? Or would a late run be in early 98? Thanks
