somthing every 98 ls1 owner should do....
Old Jun 24, 2007 | 06:09 PM
5_02ls1's Avatar
my car waqs built 11/97...asa far as performance there was an overall seat of pants feeling and the car spins easier.....
as far as 1/4 mile IDK ....my car bone stock was atleast3-4 tenths slower than the other ls1 cars with the same setup at the track....
mine was a4 2.73 geared stock and it was a dog off the line.....
If you can find a non moron working in pats at your local dealership they should be able to use your vin# and tell you which sensors are in the car....
Old Jun 25, 2007 | 12:04 AM
Thule's Avatar
can anyone send me the link for this? i realy want to do this, i have my motor out of the car rigth now, so it would be great to do this
Old Jun 25, 2007 | 03:45 PM
bww3588's Avatar
****, someone take pictures.....
Old Jun 25, 2007 | 04:58 PM
5_02ls1's Avatar
visually the top of the sensors arte the only difference...I dont know why I didnt take pics??? I normally do on everything else...
The old sensos had a long skinny plug on them...a deepwell socket had to be used...the new ones plug is short and stubby kinda looks like a mushroom...and a shallow socket can be used....
I could try and get a pic of the old sensor and harness when this rain stops here....
Old Jun 25, 2007 | 05:03 PM
ez98ls1's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/685842-98-knock-sensor-question.html
Old Jun 25, 2007 | 06:08 PM
connexion2005's Avatar
Damn...I'm a 12/98 build...I have access to professional Scan tools at work...can I check my timing with one?
Old Jun 25, 2007 | 06:11 PM
bww3588's Avatar
which ones do i have? i cant really tell. its hard to decipher....
MINE ^^^^
NOT MINE VVVV
my wires are kinda puny compared to these.
Old Jun 25, 2007 | 06:15 PM
bww3588's Avatar
are you sure its not 12/97? 12/98 would have been the 99 model year.
Old Jun 25, 2007 | 06:19 PM
Yep. Its a 12/98 Build. I've always thought that also but on the title it says 98 and it has a few 98 specific features. I can't think of all of them right now but I know back when I broke the ECT Sensor (Engine Coolant Temp) there is a 98 specific one that I had to have whereas all the others were 99-02. Oh and I have a guy locally with HpTuners who has 98 and 00 vins and he was able to work on my pcm so I'm still assuming that its a factory 98. To bad I could have used the blueblook value...lol.
Old Jun 25, 2007 | 06:48 PM
bww3588's Avatar
im not doubting its a 98, im just questioning the build date. i mean are you sure that your build date is correct?
Old Jun 25, 2007 | 06:54 PM
98SS1LWEE's Avatar
Uh, I have a late production SS and I am having knock issues, for a long while now, I wonder???? Also, Gonna need pics of the knock sensors to tell if they're early or late, so take the rubber boots off bww
  #32
It also has the 806 heads that I thought were done away with after 98 models right? I know what you are saying and everything its just that on Carfax and everything that pertains to it, its listed as a 98 ya know...
Old Jun 25, 2007 | 07:09 PM
  #33
bww3588's Avatar
where did you get your build date? carfax isint always "correct".
Old Jun 25, 2007 | 07:10 PM
  #34
bww3588's Avatar
well, i took that pic when i did the intake swap. which is why the boots arent away, and the pic better. ill just go to the GM garage and talk to them. thanks for your help tho!
Old Jun 25, 2007 | 08:04 PM
  #35
im getting my build date from the side of the door...
Old Jun 25, 2007 | 08:50 PM
  #36
peterock98's Avatar
My car was built 9/97 I had cartek turn off knock sensors with edit.
Old Jun 25, 2007 | 09:04 PM
  #37
5_02ls1's Avatar
the only way to see the sensors is to remove the boots from the valley cover....
Old Jun 25, 2007 | 09:42 PM
  #38
Black_Bird's Avatar
You can check for knock retard on a good scanner, Genesis like ours, etc.
Old Jun 27, 2007 | 09:14 PM
  #39
Starion's Avatar
After reading this thread I began researching the removal of the intake. I notice a TON of people seem to break the oil sending unit behind the intake. The question I have is how exactly does it get broken?
Does something snag on it when you pull the intake out?
Is it under the intake?
There has to be something specific that causes it to break. Trying to get as much info as possible to avoid joining the club.
Old Jun 28, 2007 | 02:09 AM
  #40
bww3588's Avatar
brake booster vacuum hose catches on it. i was careful, when i got it loose from all the bolts, i removed the hose. never broke it.
