Where is the crank position sensor
Old May 8, 2003 | 04:51 PM
Billy the Great's Avatar
Default Where is the crank position sensor
as the topic says where is this located on these ls1's?
Old May 8, 2003 | 05:01 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Where is the crank position sensor
It's in the motor upside down above the starter.
Old May 8, 2003 | 05:20 PM
StevieZ's Avatar
Rear passenger side of the block between the starter and the exhaust manifold.
Old May 8, 2003 | 06:51 PM
Holes02's Avatar
Thanks Bill.
Question for some of you guys....
When replacing it, do you have to do anything with the engine (ie. hold it @ a specific RPM) to let the crank sensor calibrate or anything like that? Or is it more or less, replace it and you're done type deal?
Old May 8, 2003 | 09:16 PM
StevieZ's Avatar
Thanks Bill.
It's plug and play. Bolt it and you're done
Old May 8, 2003 | 10:35 PM
sited12's Avatar
How do you know it went bad. Mine is no longer being read by the computer and has a code with auto tap. What would cause this problem also.
Old May 9, 2003 | 01:34 PM
Bad30th's Avatar
According to what I've read and seen, a SES code may appear from replacing the ECM or the Crank Position Sensor.
A "Crankshaft position relearn" that will relieve the SES light and code can only be done with a Tech II device (the dealer is probably the only place you'll be able to find one).
I had a problem with that code, turned out to be a bad ECM from Ed Wright. Once the ECM was replaced and flashed with the factory program the relearn was able to be successfully done and the code went away.
Happy driving,
Bad30th
Old May 9, 2003 | 02:11 PM
StevieZ's Avatar
I put a new crank sensor in my new motor and no codes were thrown. It was simple plug and play.
