Do the QTP Headers REALLY make more HP
That's the only way you are going to be able to scientifically prove anything. When you are speaking of differences of less than 10hp, it's got to be the same car, same dyno, same day to prove anything.
Also, I wasn't comparing Pacesetters to QTPs. There are obvious advantages that QTPs have over pacesetters. I'm speaking of much cheaper stainless headers compared to QTP.
Did anyone happen to see this post.
https://ls1tech.com/forums/dynamometer-results-comparisons/700678-results-qtp-hvmc-vs-pacesetters.html
It shows gains.
3100 it is 18 hp and 30 ft lbs
8 hp 6 ft-lbs peak
This is exactly what i wanted to see....
Swap involved:
SLP LT to QTP HVMC LT
LS6 to FAST 90 intake
3" TD X-pipe to QTP (Mufflex) Y-pipe and SLP 2OTL catback
Decent gains. Car later made 480rwhp with further tuning and some tweaking of the cam degree. (stock cube h/c LS1)
For someone looking to milk every pony out of their setup, there's no reason not to get the HVMC's.
this is what i said:
i made two totally different comparisons. i made a comparison of 5 years ago and 5 years into the future.
5 years ago, there was less competition, so an increase in companies making the headers caused the prices to go down. this is why headers were more expensive 5 years ago.
however, NOW, the market is flooded with competition. a ton of companies make headers in different grades of steel. because the market is flooded, the price increase of raw materials will cause the header's price to increase faster than the increased competition will cause it to decrease. this will cause header prices to rise 5 years into the future.
you guys need to learn to read before you point the fingers. learn to read. either you're a terrible reader or you're a liar. either way, it's not good.
I've noticed as of late Kooks and American Racing having them while QTP is the only company really pimping them...
only QTP and ARH use HVMC's, and IMO, QTP has the best merge in the business. edelbrock may use HVMC's in their stainless version, but i've never seen pics of stainless edelbrocks.
....Some people have found small low and mid-range torque improvements using an H-pipe. But at high RPM, the gases cannot bleed across the H-pipe fast enough to help power very much. The double cross, X-crossover, is an improvement beyond the H-pipe, but does not resynchronize pulsing and pressure spikes completely.
X benefits are up high.
Same car gained 2mph in the 1/4 with the X pipe over a conventional (SLP) Y-pipe when it was a cam-only setup.
Furthermore, that setup ran on an apple for apples SLP LT/ 3" X pipe to QTP HVMC LT/ Mufflex Y pipe swap for a few weeks before the 90/90 went on and there was significant improvement in midrange response from the exhaust swap alone.
However with my old setup, with the QTP HVMC LT's and the Mufflex Y-pipe, gains were seen both in midrange response and with peak totals. IMO, I attribute the gains seen in the midrange to the flowmaster scavenger merge collector design of the Y-pipe, the upper range gains a result of the 90/90 intake, and the HVMC's supporting both mid and upper range gains. Perhaps with the X-pipe still on, it would have seen even higher peak gains. That would be my guess, yet I was very pleased with the response (and practicality) of the Y-pipe setup- so it turned up to be a great compromise.
Nevertheless, the HVMC's proved a good choice- both for SOTP and dyno gains, getting back on topic.
