Results: QTP HVMC vs. Pacesetters
Old Apr 21, 2007 | 04:54 PM
WS6FirebirdTA00's Avatar
Default Results: QTP HVMC vs. Pacesetters
Both 1 3/4", both on the same dyno and after no other changes. Only difference is it was 16º hotter for the latest run.
The lower end of the graph I was not quite full throttle when I started the run. Air fuel was the same, but the WB came out of the exhuast so I dont have it on here, it was ~12.9 across the board, but need to do a little work around 4400 rpm. No smoothing to take false torque peak out.
Right at 469/431
Gains (based on final old numbers, this graph just shows the low end increase):
8 hp
6 ft-lbs
26 ft-lbs at 3200
No to bad for a dyno that everyone bitches about being low
Also, FWIW, I dynoed with the Holley powershot, new paper air filter, and no filter, and saw ZERO changes, which is what I expected.
Attached Thumbnails Results: QTP HVMC vs. Pacesetters-untitled.jpg
Old Apr 21, 2007 | 05:29 PM
Patrick G's Avatar
LS1 Tech Administrator
Very impressive gains in the mid-range Mike. Kinda explains why the Corvettes with HVMCs are so strong in the 3000-3500 range. You gotta torquey setup for sure!!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 21, 2007 | 05:40 PM
30th t/a's Avatar
WOW nice numbers! that is a pretty good gain just from headers. Will you be going to the track anytime soon?
Old Apr 21, 2007 | 06:11 PM
venom ws7's Avatar
GREAT gain from just heades those QTP HVMC is a piece of art.
Oh great numbers through 9inch and 431tq very nice.
Old Apr 21, 2007 | 06:12 PM
chrs1313's Avatar
what was 16 degrees hotter? air temp or water temp...was a correction factor used...
Old Apr 21, 2007 | 06:24 PM
Thanks guys.
Yes it was SAE correction. The air temp was 16º hotter and the motor was hot (did not cool off between runs). Would have helped but I dont let the car cool off that much on the street or track so I didnt want to do it on the dyno. Also had my tires at about mid 20's psi as well (25-27 or so).
I am going to get to the track as soon as MT releases the 295/45/17's, or else I run out of gear lol
Old Apr 21, 2007 | 07:07 PM
98camaroLS1M6's Avatar
nice comparison! QTP FTW!
Old Apr 21, 2007 | 09:07 PM
dug's Avatar
dug
was there a ypipe or is your exhaust true duals? Yeah, 10hp is a huge gain just from headers
Old Apr 21, 2007 | 10:14 PM
ypipe, I have the QTP one on there, and before I had a TSP one I modified because the way is merged was not good at all. After I got done with it, it was pretty good.
Old Apr 21, 2007 | 10:48 PM
venom ws7's Avatar
was that through the GMMG catback or you have cutout?
Old Apr 21, 2007 | 11:00 PM
cutout, through the catback lost 6 hp, I will try and dig up that graph and I will post it.
Old Apr 21, 2007 | 11:05 PM
Here you go, this was a dyno right after the 9" install (when I was checking for losses). About a 4 hp loss and 5 ft lbs loss through GMMG.
BTW, thanks Pat for posting that graph like that for me
Attached Thumbnails Results: QTP HVMC vs. Pacesetters-cutout.jpg
Old Apr 21, 2007 | 11:26 PM
dug's Avatar
dug
did it have a 4" collector like the qtp ypipe?
Old Apr 21, 2007 | 11:32 PM
no it didnt, but the exhaust is still all going into the 3" pipe that leads to the cutout.
Old Apr 21, 2007 | 11:49 PM
dug's Avatar
dug
thanks for sharing the info. got any videos of the car?
Old Apr 21, 2007 | 11:50 PM
Not recently, have one of a while back on the dyno but I have to find it haha
Old Apr 22, 2007 | 12:57 AM
bad95killer's Avatar
Very nice gains man & thanks for such a great comparsion buddy
peace
Old Apr 22, 2007 | 01:03 AM
HOSS's Avatar
good **** Mike.
Old Apr 22, 2007 | 01:43 AM
venom ws7's Avatar
wow only lost 4hp the GMMG is great flowing catback.
Great numbers again just how loud is your car when closed cutout?
Old Apr 22, 2007 | 02:21 AM
Louie83's Avatar
Nice set-up, I'm on my way towards something very, very similar.
