ENGINE NOISE?
Old May 17, 2003 | 04:46 AM
1320_PERFORMANCE's Avatar
Default ENGINE NOISE?
WAS JES WONDERING IF A TAPPING NOISE FROM ENGINE-2002 Z28 M6 IS NORMAL? DINT WANNA BRING IT IN TO THE DEALERSHIP AND FEEL DUMB. I ONLY HEAR IT WHEN CAR IS IDLING! WARM OR COLD ENGINE! SOMETIMES IT SEEMS LIKE ITS COMMIN FROM UNDER THE CAR, IT NEVER GOES AWAY. THANX IN ADVANCE
Old May 17, 2003 | 11:01 AM
BadAssBlueStripeTA's Avatar
Default Re: ENGINE NOISE?
Well, I had a similar noise...the guys on my other site said it was a piston slap? I'm not sure, but they said its common on LS1's and not a big deal. However, I haven't really noticed it much anymore, well, that's since my belt is focked up.
Old May 17, 2003 | 11:06 AM
deviate42's Avatar
i had a sound like that when one of my belts gave out.
Dont ever feel dumb by taking your car to the dealership. Thats how problems get worse when they arent taken care of. If you dont feel comfortable, just give them a call and tell them the problem.
if my dealer didnt void my warrenty, id hangout there all the time
Old May 17, 2003 | 04:55 PM
WS6 RULES's Avatar
My 2002 clicks and taps at idle also, I thought they all did it.
Old May 17, 2003 | 06:34 PM
NiceTry's Avatar
i had a pretty bad tick and when i took the valve covers off i pulled out a pushrod that was in two pieces lol. but if it is just at idle i dunno, if it's a pushrod or lifter the tick will get faster with the rpms
Old May 18, 2003 | 10:42 PM
2001CamaroGuy's Avatar
aluminum blocks trasfer noise much better than iron.
You may have a little piston slap, but a lot if it is just the sound eccoing through the block. The noise gets really bad when you start doing high lift cams and heavy springs.
Old May 23, 2003 | 03:09 PM
CRCWS6's Avatar
sounds to me like it's the lifters. As my oil loses its viscosity, the sound seems to get worse. As mentioned before, does the speed of the sound increase with rpm's or is it constant?
Old May 24, 2003 | 07:54 AM
WILWAXU's Avatar
Honestly... my motor makes all kinds of racket hot or cold. I've tried different oils, finally just decided the performance was worth a little noise. Figure if it was going to come apart, it would have already done it
