Under The Axle
Old Jul 25, 2007 | 10:31 AM
mattraypharbor's Avatar
Default Under The Axle
Has anyone gone this route? I have seen a few threads about people doing this...full 3" exhaust with 2 18" dynomax bullits ending right before the axle like a dump would but instead you run 3" pipes from there under the axle and out the back? My Question is will the exhaust hit the rearend when i go ever bumps? ext ext....................
Old Jul 25, 2007 | 10:48 AM
93redBIRDman's Avatar
I dont know what it'd hit, but it'd look disgusting!
Old Jul 25, 2007 | 10:50 AM
brad8266's Avatar
my duals are under the axle, and no they dont hit the axle.
Old Jul 25, 2007 | 11:08 AM
tylerdj's Avatar
Several people have ran them under the axle...I plan on doing this in a few weeks. You can see some that people have done under the True duals sticky at the top of the page.
Old Jul 25, 2007 | 11:29 AM
thanks guys...ANYONE else with experiance?
Old Jul 25, 2007 | 11:37 AM
Im looking for pics!!! i searched threw the stickes and havent found what im looking for...I want it to look clean...Ive got dumps right before the axles now and i want to just run a pipe from them with a slight angle outwards to the side of the car and than abrublty stop and streight out the back..something with smooth bends and doesent slook like *** ive seen a pic of it i just cant find it...
Old Jul 25, 2007 | 12:16 PM
PAGregSS's Avatar
See stickies at the top of this forum.
Short answer is, yes, there is a possibility of scraping. Depends on the size of the bump. If you're referring to speed bumps, the exhaust will raise when the rear tires drive up the speed bump, so you shouldn't scrape
Old Jul 25, 2007 | 12:19 PM
PAGregSS's Avatar
Mattraypharbor, is this the pic you were looking for:
Old Jul 25, 2007 | 01:08 PM
tylerdj's Avatar
Is that your setup PAGregSS
Old Jul 25, 2007 | 01:32 PM
I think so.....the pic i saw was from the rear while it was on the ground. Do you have that pic i just want to get a good idea on how to make it look decent?
Old Jul 25, 2007 | 02:45 PM
PAGregSS's Avatar
No, at the moment I just have the TSP true duals dumped at the axle. I've been searching for the best way to run them the rest of the way out the back, under the axle, and I came across that picture a while back. Looked good, but not sure if the 90 degree bends are that great for flow.
Old Jul 25, 2007 | 07:45 PM
SVC707's Avatar
i believe i have a picture or two in my sig link somewhere
Old Jul 26, 2007 | 12:06 AM
bump..
Old Jul 26, 2007 | 08:37 AM
anyone else ?
Old Jul 26, 2007 | 08:40 AM
tylerdj's Avatar
I would like to see some setups too.
Old Jul 26, 2007 | 08:50 AM
BerryWS6's Avatar
I had that for awhile, 3" h-pipe with 1 chambers then 2 1/2 pipe after under the axle
and a little sound clip
