how does the 99-02 coolant guage work
Old Jul 27, 2007 | 10:48 PM
cals400ex's Avatar
Default how does the 99-02 coolant guage work
ok, i hear this coolant guage sucks but i never really hear why. does it give false readings or what?
Old Jul 28, 2007 | 12:31 AM
Fibbado's Avatar
basically it sits at... 180ish unless it really overheats and then it will move to 210+
Old Jul 28, 2007 | 01:44 AM
99NMB's Avatar
Mine sits at 210 all the time. stock thermostat though.
Old Jul 28, 2007 | 10:18 AM
killerinparadise's Avatar
Mine also sits at 210 and I have the stock thermostat, he must have a different on in there. I think they say it sucks because it doesn't really give you an accurate temperature it's only lets you know when your really overheating
Old Jul 28, 2007 | 10:58 AM
'00_Z's Avatar
yeah, it's kinda like the idiot light...evolved!
Old Jul 28, 2007 | 11:51 AM
TORCHD 02 TA's Avatar
it does not work, it is a dummy. It works off of a resisitor. the only ones thta realyl worked are i think 94-98. I know my buddies 97 works that is for damn sure.
but i have a 160 in mine, and it still sits below 210
Old Jul 28, 2007 | 12:44 PM
cals400ex's Avatar
so say your car is overheating, will it still read 210 or so? i just dont' get it.
Old Jul 28, 2007 | 01:26 PM
Slvr00Bird's Avatar
98 was the last year for the actual reading gauges I believe.. I've heard the later ones just take an average of what the temperature is and it sets at it instead of giving you an acurate read... just to make everyone feel nice and fuzzy about their engine when in actuality it is varying..
But I've also heard that people use the 160 stat and it still goes up to 210 so maybe they're just complete dummy gauges..
Old Jul 28, 2007 | 01:44 PM
ErikElvis's Avatar
My car sits right at 210 all the time. Before I replaced the ECT sensor it would read 3/4 between the 150 to 210. Dont these things have 195 degree thermostats?
Old Jul 28, 2007 | 02:56 PM
cals400ex's Avatar
i thought the thermostats were 180 stock
Old Jul 28, 2007 | 03:10 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Stock thermostat is a 187.
As for the gauge, I think GM put the idiot gauge in in 1999 to keep their customers from coming in and complaining that their cars *might* be running hot...it was more for the average buyer that doesn't know much about cars...or it could be to keep the old school guys from coming in that think a car should run at a cooler temp like their old muscle cars used to.
The signal is actually good though...if you scan the OBD-II port, you do get an accurate reading of the coolant temp...the guage just doesn't display it.
If the car is overheating, you will know it...the gauge works perfectly fine, GM just reduced the gauge's sensitivity in the normal coolant temp operating range.
Old Jul 28, 2007 | 10:29 PM
chae's Avatar
https://ls1tech.com/forums/showpost....9&postcount=11
