Cam or M6 swap?
Have you considered just buying a M6 car, less work involved. But if you do the swap, I'd put in a ls7 clutch at the same time.
if a street racer then i say t56.
if drag car stay auto.
or if u just have to have t56 then i think you know your answer.
hope this helps
Totally offtopic but your car makes great bolt on power. Any track times?
Thanks, the tuner and I were surprized with the numbers. The closest I have to track numbers are from a g-tech on the street. 13.1 @ 110 with a 2.3 60ft with a friend in the passenger seat, and a trunk full of tools. I hope to go to the track soon. I'm confident it will run high 12's because I've own 13 second cars before and my SOTP tells me this ones a little faster
As for the Tranny, It all depends on what you want. every car I owned was a stick until I bought the camaro, and the auto was cool but I just had to have a T56. I haven't seen the track for 3 years and I love having more control over the car and RPM range so I did the swap first. Just kept buying parts for the cam here and there and finally installed in a few weeks ago. But it was definately worth the wait for the cam for me. I've been having a blast with the manual trans. All in all it's what you want to drive and if you can wait to add some extra HP. The T56 gave me better gas mileage and does free up some horsepower but it was hardly noticeable. And like Jimm98LS1 said if you do a cam with the A4 you really won't benefit unless you get a higher stall, shift kit, and DEFINATELY need a tune. though you'll have to tune the T56 swap also.
The A4 is gonna require you keep your tuner on speed dial for major mods......but around here its not at all uncommon to see a full exhuast,stalled,tuned A4 go mid to low 12s (with a decent stall that is, 3200+) at the track.
