Question about running duals under axle.
Old Aug 7, 2007 | 09:45 PM
HossZ28's Avatar
Default Question about running duals under axle.
I plan on getting duals in the near future after my header install. I am still unsure of how I want to run the duals, but I am leaning more towards under the axle. Do any of you guys who have this setup regret doing it this way? What is your setup? Post any pics if you have any.
Old Aug 7, 2007 | 09:57 PM
Reject's Avatar
i run em under, never had any scrapping, it reminds me of the how the cobra's look like when you can see the pipes
Old Aug 7, 2007 | 10:37 PM
HossZ28's Avatar
Is it a pain taking it off when you want to put it on a lift? That is really my only concern with running it that way. I am not sure if it would look good to have the mufflers after the axle at an angle and then right off to the tips. It seems like it would be either badass or really ricey.
What size exhaust are you running? can you post any pics?
Old Aug 7, 2007 | 10:44 PM
Reject's Avatar
http://reject.sleepingz.com/video/moroso%20TD.wmv
you can kind of see them, i have the muffler's before the rear end, and just pipe running to the back, run 2.5 inch pipe becuase i'm lowered
and it's a bitch to lift the car, my only complaint
Old Aug 8, 2007 | 01:06 AM
SVC707's Avatar
https://ls1tech.com/forums/showthrea...5&page=9&pp=10
duals under, 4 mufflers and 2 cats
Old Aug 8, 2007 | 07:33 AM
Reject's Avatar
sound clip? must be pretty quite
Old Aug 8, 2007 | 08:29 AM
SVC707's Avatar
quiet? go to the next page on the link
Old Aug 8, 2007 | 10:20 AM
Reject's Avatar
damn thought it would be quite with 4 mufflers!
Old Aug 8, 2007 | 10:42 AM
SVC707's Avatar
3" all the way back, 408ci, 24x/25x cam, procharged built
Old Aug 8, 2007 | 10:44 AM
Reject's Avatar
big motor, no wonder it's so loud, wonder how much quieter it would be on a 346 with a non-donkey cam
Old Aug 8, 2007 | 10:57 AM
SVC707's Avatar
most likely not too bad. when i did cut out motor vs motor, this engine sounded good!!!!! i did the swap at home so i was able to get a good comparison.
Old Aug 8, 2007 | 11:50 AM
2002ssls1's Avatar
I have 2.5" pipes under the axle, and single chamber flowmasters before the rear. There is no problem with puting the car on a lift, nothing has to be taken off. The pipes are bent perfectly so that the rear just barely touches the pipes.
Old Aug 8, 2007 | 12:05 PM
Reject's Avatar
are you lowered? i'm lowered so that was the reason i went under, i have eiback (BOOOO) springs and the rear tires are almost going in the fender gap!
Old Aug 8, 2007 | 01:31 PM
speed_demon24's Avatar
http://s86.photobucket.com/albums/k1...n24/?start=all
Lowered with strano springs, 3" from collector to exhaust tip. The only part that scrapes is my headers on speed bumps, I haven't bottomed my true duals yet.
