ypipe and manifold differences
Old Aug 10, 2007 | 12:37 AM
Loochy88's Avatar
Default ypipe and manifold differences
would stock manifolds from an 02 bolt up to the ypipe on a 99? I know the manifolds are a bit different (and slightly better), but do they meet up to the ypipe in the same location?
Old Aug 10, 2007 | 06:16 PM
1cleanbird's Avatar
Yes they do. They should at least.
Old Aug 10, 2007 | 08:55 PM
Loochy88's Avatar
then why are all ory's for stock manifolds specific to either the 98 style or the 02 style setups.
check out stainlessworks.com website to see what im talking about. Mac also makes a ypipe that they only claim fits the 98 style setup.
Old Aug 10, 2007 | 10:24 PM
sixvi6-camaro's Avatar
The 00-02 y pipes have different cats and a different y-pipe but I'm unsure if the manifolds from an 00+ car will work on a y made for the stock 99 manifolds. I've necer seen both up close to know.
Old Aug 11, 2007 | 12:24 AM
Soul TKR's Avatar
as far as i know the cats are bolted up on the y-pipes on the 00-02 cars and on the 98-99 cars they are welded into the y-pipe as one piece... I could be wrong but my 99 has one "SOLID" y-pipe with cats welded in...
Old Aug 11, 2007 | 12:51 AM
Loochy88's Avatar
right, i get that... but are they the same shape/lentgh? if i took mine off my 99 would it bolt up to an 02 for instance?
Old Mar 13, 2010 | 07:36 PM
veddersbetter's Avatar
Dragging up an old thread instead of starting a new one. Anyone have an answer to this?
Im wanting to buy an ORY off a 99 to fit my 01.
Thanks for any info
Old Mar 14, 2010 | 01:22 PM
Someone has to know lol.. Will a 99 ORY bolt up to an 01?
Old Mar 14, 2010 | 10:59 PM
Fireberg's Avatar
No, they will not match up on the passenger side.
The drivers side uses the same cat for all years.
The passenger side cat on the 98 and 99 cars is under the floor, where as the 00-02 cars the cat bolts directly to the manifold. because of this the "down pipe" on the earlier manifolds is closer to the fire wall.
This is also why people with the later manifolds can reach spark plug # 8 from under the car; try to do that with a 1998 or 1999.
Old Mar 14, 2010 | 11:03 PM
180ls1's Avatar
agreed
Old Mar 15, 2010 | 02:04 PM
Thanks for the info... I appreciate it.
