Question about powersteering cooler?
exchanger, not a fluid-air exchanger (except
some incidental convection which doesn't count
for much). Polishing only matters to radiative
heat transfer and I bet the difference between
rough and polished aluminum there, isn't much.
Aluminum wrap in the oven is a convection barrier,
little to do with radiative heat transfer. At 200F
operating temps radiative transfer is no big help
anyway. It's all conductive (fluid-wall-fluid) in
this application.
You could just paint it black. Less work and less
of a "what's that anyway?".
As for polishing, if you would have put this in the detail section you would have got your answers much easier and more thorough.
But just to polish, I removed mine and polished it about 2 years ago and had no problems what so ever. Just do like some one else said about bleeding. Turn steering wheel full lock 3 or 4 times. You will notice some mild bubbling in your fill tank.
