LS6 intake question
Old Jun 6, 2003 | 10:10 PM
WS6SpdTA's Avatar
Default LS6 intake question
If I install an 02 LS6 intake on a 99 LS1 engine, what all do I need to make it work? I've heard that you can remove the ribs underneath the intake with a chisel or grinder.
What about the EGR that goes on the top of the LS1 intake... the LS6 manifold doesnt have it.
Thanks for the info in advance.
Old Jun 6, 2003 | 10:31 PM
JoSeY's Avatar
Default Re: LS6 intake question
You can purchase and LS6 intake with EGR provisions from SLP. Or you can just get rid of the EGR system all together...
Old Jun 7, 2003 | 11:59 PM
Jammer's Avatar
Ditch the egr..and if you feel like grinding, add the ls6 valley pan set up, you'll need to grind a nub off the block though.
Old Jun 8, 2003 | 06:59 AM
malibu350's Avatar
When I did mine I just cut the the part of the coolant tube off that goes under the intake. And welded up the ends. I've had mine done for almost a year now and no over heating problems at all...and ditched the EGR
Old Jun 8, 2003 | 11:31 AM
WhiteDeathLS1's Avatar
I also tossed the EGR; I always hated it. Now I need some LS1 Edit to get rid of it for good.
Old Jun 8, 2003 | 12:45 PM
PongoX11's Avatar
I tossed my EGR, and also bought a new coolant pipe (12568478) that just runs on the front from left to right and doesnt run towards the back of the block. And two plugs (12563325) for the back holes.
Old Jun 8, 2003 | 01:07 PM
DaleMX's Avatar
Tossed EGR, got new coolant pipe and plugs.
Old Jun 8, 2003 | 01:51 PM
Jabroni's Avatar
For a basic install, there's no need to grind anything. Just pop the green retainers off the existing coolant tube near the knock sensors and swap the intakes after you install a new coolant crossover pipe or modify the existing one. Since no one else posted it try: www.ls1howto.com
Old Jun 10, 2003 | 11:59 PM
WS6SpdTA's Avatar
Thanks a lot guys. I'll check into that link.
