slp lid install
Old Oct 15, 2007 | 05:27 PM
john shea's Avatar
Default slp lid install
I was having trouble sliding the lid onto the maf. I finally put the cooked lid
over low heat on the stove and muscled that sob on. That connection is way too tight.
Old Oct 15, 2007 | 07:12 PM
JScamaro's Avatar
Yea with mine I used a hair dryer to heat up the plastic and it slid on much easier.
Old Oct 15, 2007 | 07:17 PM
camaroguy26's Avatar
yeah I had one and it was so tight it got a huge crack in it. you should reem out the inside a little bit or cut a couple short slits in it to give it some flexibility
Old Oct 15, 2007 | 07:28 PM
SamhainZ28's Avatar
i beat mine in with a rubber mallet, come out ok.
Old Oct 15, 2007 | 09:03 PM
tee-boy's Avatar
Default ddd
had same problem w/ maf. Did the front top lip of the lid slide inside of the front bottom of the lid (in between the metal clips)? that was only way I could get a decent fit. BTW, dynoed the car @ Thunder Racing w/ lid. Car averaged 302hp. Then, last run dynoed at 106 w/ the lid unlatched.
Old Oct 15, 2007 | 09:08 PM
ShortChevy's Avatar
Hmm, might just took light pressure and went right together. Must just have the touch
Old Oct 15, 2007 | 10:16 PM
jetlag's Avatar
Hmm..mine went in easy...
Old Oct 16, 2007 | 12:55 AM
Eric95's Avatar
mine was a really tight fit...took my dad and i about 30 minutes to finally get it to go on all the way..heating it up a bit probably would have helped but i didnt think of that for some reason
Old Oct 16, 2007 | 07:22 AM
RedRocketZ28's Avatar
Mine was a SOB to get in as well. I put some vasoline on the inside of the lid and heated it. Went in real easy that way.
Old Oct 16, 2007 | 12:59 PM
RedRallyeZ's Avatar
i didnt have a problem getting the maf into the new lid, i had to hack up the old lid to get it out though
Old Oct 16, 2007 | 01:22 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I had the same problem. I put my maf in the freezer, heated the lid with the oven door open, then put soap on the inside of the lid. It still wouldn't go on. The fit was so tight the lip on the maf was grinding rings into the lid. Eventually I just refroze the maf, resoaped the lid, took a propane torch to the lid, and basically melted it. It popped in after that.
Keep in mind a few months ago they redesigned the lid. See thread:
https://ls1tech.com/forums/showthrea...id#post6911881
If you have an older one aka pre March you got off easy. For all of you who have a post March one or plan on getting one have fun.
Old Oct 16, 2007 | 01:26 PM
02 1LE HAWK's Avatar
Yeah, mine was one of the newer ones. It was a full on butch to get it in. Lots of swears I didn't even know I knew.
-Matt
Old Oct 16, 2007 | 02:05 PM
mikenews's Avatar
Had same problem! What the hell SLP!! I actually took 80 grit paper to the small lip that is on the aluminum housing of maf. Worked perfectly, but still had to use some force to get it on.
Old Oct 16, 2007 | 03:54 PM
DMONEY06's Avatar
mine went in like a breeze too!
Old Oct 17, 2007 | 07:46 PM
OWN3D BY MY PROF!
I would try to take pictures of the inside lip of mine, but I'm scared of having to put it back together again.
