LS6 Intake or Ported 853 Heads
Currently I have a 98 LS1 from a SS Camaro in my 96, its a M6 setup, current mods are below. Just wanted to see from which I would see more gains from. Not sure how well a set of ported 853's would flow but hopefully they would flow pretty good. Does anyone think they would flow like LS6 heads? The heads were milled a little I think to raise the compression. My car has the stock 806 castings which I heard, stink.
Specs:
5.7L 346 ci. LS1 (98 SS Camaro Engine)
370 HP @ 5500 RPM est
385 TQ @ 4500 RPM est
Mods:
-Hurst Competition Plus Short Throw Shifter
-F1 Lightweight Flywheel
-Walbro 255lph Fuel Pump
-Hooker Super Comp LT Headers
-G2 Cold Air Intake
-K&N Air Filter
-Ported MAF Sensor
-Rebuilt T-56 w/ Beefed Shift Forks
-180 Thermostat
-Copper Header Collector Gaskets
-No AIR
-No A/C
-Skip Shift Delete
-6,500 Rev Limit
-No Governor
-No Cats
-Royal Purple 5w30
-LG Performance 2.5 in. Lowering Kit
-ES T/A Mount
-ES Tranny Mounts
-X-Pipe w/ Dynomax Bullets
-Centerforce Dual Friction Clutch
-LCA Relocation Brackets
-Powerstop Coated Cross Drilled Rotors
-Royal Purple HP 5w30
-Hurst Hot Shift HP ATF
Apperance Mods:
-17x11.0 Black Grandsport ZR1's 315/35ZR17
-Nitto Drag Radials 315/35ZR17
Anyways, moral of the story, yes PORTED 853's will flow a lot more than STOCK ls6 heads...
haha
Or what the hell, do both.
