Tick after LS6 install
Old Nov 28, 2007 | 05:24 PM
ShortChevy's Avatar
Default Tick after LS6 install
Well as the title states, I'm wondering if after the ls6 install took place, anyone heard any noises. I have what sounds almost like a lifter tick. Only thing is it doesn't go with the RPM. Now I didn't go the ls6 coolent pipe way, I ground the ribs out. I'm thinking maybe the vaper pipes is rubbing or tapping the valley cover or intake. Let me know what you guys think or if you know of anything else that ticks.
Old Nov 28, 2007 | 06:02 PM
SchultzLT1's Avatar
check your spark plug wires
Old Nov 28, 2007 | 07:37 PM
99Bluz28's Avatar
Hi ShortChevy,
I believe the sound you're hearing is the injectors sound being amplifed between the LS6 intake and valley cover. I bet your LS6 intake didn't have the foam gasket on the bottom front and back of the intake(mine didn't), so the sound is being amplifed instead of being absorbed by the foam gasket.
I went through the same thing 2 1/2 months ago.
I also retorqued my intake bolts after about a week and they tightened up a little bit.That seemed to help a little with the noise.
Old Nov 28, 2007 | 07:44 PM
King Nothing's Avatar
Originally Posted by 99Bluz28
Hi ShortChevy,
know where one could get that foam piece and put it back in? mine didn't come with it either
Old Nov 28, 2007 | 09:17 PM
99Bluz28's Avatar
You can probably find some kind of foam gasket material at any large home improvement/hardware store. Make sure you get some that compresses easy, 1/2" to 3/4" thick should be about right.
Old Nov 29, 2007 | 12:33 AM
ShortChevy's Avatar
Thanks, thats kind of what I was thinking as well. The sound is exactly like listening to an injecter with a stechiscope. I guess I screwed up big time. My intake had those foam pads on it but I removed them becuase I had to grind the bottem to clear the pipes.
Old Nov 29, 2007 | 10:20 AM
is it harmful at all to our engine or performance if it's not under the intake?
Old Nov 29, 2007 | 12:12 PM
Black99CamaroSS's Avatar
I think the foam stops stuff from messing up the knock sensors too.
Old Nov 29, 2007 | 12:33 PM
kenp's Avatar
The foam pieces come with an intake gasket kit.
Old Nov 29, 2007 | 06:35 PM
but is it harmful if it's not there?
Old Nov 29, 2007 | 07:23 PM
SchultzLT1's Avatar
no you don't need the foam thing, it won't hurt.
and I don't have a ticking after my LS6 install with no insulators...
Old Nov 29, 2007 | 08:07 PM
thanks schultz!! btw who's *** is in your avatar?????
Old Nov 29, 2007 | 08:13 PM
Viper's Avatar
From back in the day, the foam was discovered to help block water getting in. If water gets in it tends to rust the knock sensors. FWIW.
Old Nov 29, 2007 | 08:37 PM
SchultzLT1's Avatar
Its an ex-gf's ***. It was awesome. Still is. Someday I'll switch to my current gf's ***, its even nicer. I'm all about the *** so all my gf's are required to have it.
Old Nov 29, 2007 | 08:44 PM
yes it is!! i've got acouple ex-gf's asses on my comp so maybe i'll go with a new avatar
Old Nov 29, 2007 | 10:51 PM
SchultzLT1's Avatar
got the new one up
not that flattering, gotta get another
