''fast 90 to much''
Old Nov 29, 2007 | 09:44 PM
turners98ws6's Avatar
Default ''fast 90 to much''
I put a ported fast 90mm intake and tb on my 99 ta.I've got long tube headers, ory, hp tuners,slp lid,free mods.would that be to much air and fuel for a stock motor.it was said to be 22 hp over ls6 intake,but this car didnt respond to it as well as my 98 ta did to the slp ls6 intake with stock tb.please help!!
Old Nov 29, 2007 | 09:50 PM
Black99CamaroSS's Avatar
Most people will say the fast 90 is not worth it till heads and cam. How did you mate up the stock TB to a fast 90???
Old Nov 29, 2007 | 09:54 PM
the tb is a fast90mm also.
Old Nov 29, 2007 | 09:59 PM
GMmexican's Avatar
Ill trade you my ls6 manifold plus cash
Old Nov 29, 2007 | 10:05 PM
**** man i got bout 1,800 bucks in the intake and tb.had the intake sanded and painted gloss black,ported and all that mess.
Old Nov 29, 2007 | 10:17 PM
could i put my stock tb back on the 90mm intake.does it make sense that maybe im getting to much air? my 98 had better 60 ft times with all the same stuff.maybe less air and fuel flow would give me better acceleration on the lower rpm's??
Old Nov 29, 2007 | 10:22 PM
merriman44's Avatar
Lots of air through a smaller engine and all you end up doing is slowing your velocities down. Makes for a sluggish combo. In this case bigger is not always better. People are using (I'll one of them) the 90mm tb's on 400+ ci engines.
I think your choking it, and the smaller tb isn't probably going to help much here. Might be better to go back to the ls6 for now and wait til you have more cubes.
Diclaimer: this is all coming from a newly converted small block chevy guy. All of my post would apply to a sbc but may not apply to the ls series. So take it with a grain of salt.
Old Nov 29, 2007 | 10:48 PM
thanks man! back to the drawing board again!!
Old Nov 29, 2007 | 11:43 PM
cruiSSin LS1's Avatar
:d:d:d:d:d:d:d
Old Nov 30, 2007 | 12:30 AM
wildta's Avatar
I think your air and fuel ratio might be off now. It might be to rich. you need a proper tune.
Old Nov 30, 2007 | 01:19 AM
chuckyt1's Avatar
It is too much for a stock cubed, stock headed, stock cam motor. Think about volumetric efficencies. It's kinda like bolting a Dominator carb an a 350... Too much air...
Old Nov 30, 2007 | 05:59 AM
ringram's Avatar
Better buy some heads and a cam now then dude, then things will fly!
Old Nov 30, 2007 | 06:41 AM
BlackScreaminMachine's Avatar
Internet Mechanic
22hp is with H/C in consideration, + tune
It is a better intake you just need to match it to the heads which makes the power and the cam that dictates how the power is made.
Old Nov 30, 2007 | 08:40 AM
HaulinHawk's Avatar
Ditto!
Old Nov 30, 2007 | 09:22 AM
radkon's Avatar
He's dead on. Without heads and a cam your intake is outflowing your internals thereby slowing the velocity of the air down. When I put a non ported FAST 78 on my setup (stock 241 heads and a TR224) I picked up 10 HP (up top) but lost 7 ftlbs of torque (down low, after the tune) for similar reasons.
Thats why the FAST is usually last on the mod list.
Old Nov 30, 2007 | 11:41 AM
trukk's Avatar
This is exactly like the results I just posted yesterday:
https://ls1tech.com/forums/generation-iii-external-engine/822540-stock-head-cam-346-ls6-w-bolton-s-pre-post-fast-90-90-results.html
As a side note, my injectors (28lb ls6) were at 92%. I peeked at 380 rwhp on a MD1100. (headers, cat back, cai, 90/90 + dyno tune).
I spent 2K on my setup too (90/90 + ported).
Just start planning your cam now. It should really benefit once it's in.
Good luck, and post your results once you're done.
-Chris
Old Nov 30, 2007 | 10:06 PM
greysteel_M6's Avatar
Too much air? I suppose it makes sense that it could slow down the charge velocities but it seems counter intuitive, waiting for that hyped wieand coming out in the spring.
Old Dec 1, 2007 | 09:12 AM
tee-boy's Avatar
No it's not. Believe me, I have stock heads (98's in fact), cam, and exhaust manifolds. The car runs fine (even better) w/ the FAST 90/NW 90.
It's not anything like putting too big of a carb. These motors are fuel injected and don't need carb pressure signaling.
If you plan to do an intake before you do h/c, do it right the first time.
Old Dec 1, 2007 | 09:31 AM
svtwhat?'s Avatar
without H/C it isnt gonna make much of a difference over an ls6. no point really in supplying their if you dont have the other parts to flow it.
Old Dec 1, 2007 | 09:36 AM
edcmat-l1's Avatar
Its still all about velocity, and putting that manifold on a small cam small motor, you're gonna decrease intake velocity. It will drop power everywhere except a small range up top.
