Finally got all my cam parts ordered!
What do you guys think? This is going on a 2000 Firehawk, w/ 4.10's and a cutout. I hope I'm not missing anything vital for the install...Most of the tools I'm going to borrow from AutoZone.
I'm in the same exact spot as you, gearing up for a cam install. I am also comiling a parts list.
Looks like the oil pump you spec'd is for an SBC/LT1 ( http://www.thunderracing.com/catalog...&vid=6&pcid=83 ), not an LSx.
Do you want this instead:
http://www.thunderracing.com/catalog...&vid=3&pcid=83
Do you also need (?):
Cam retainer Bolt ( not sure if this comes in the CAMPK-PG):
http://www.thunderracing.com/catalog...id=17&pcid=157
113-134-1002
$7.49
Are you going to do an UD pulley at the same time as the cam? I plan to since it will be off. Note: since I have a CTS-V, I need to use the Corvette kit.
ASP Harmonic Balancer w/ ARP bolts
http://www.texas-speed.com/shop/item...d=642&catid=16
NOTE: Choose optional Pulley Bolt - ARP ($27.99)
19-941020
$273.98
I'm also going to do injectors since I am at 92% IDC right now (380 rwhp, ls6 w/ all boltons except EWP & UD Pulley, will probabaly be up to 420+ish w/cam, so I'll need that injector, when runniong 5000+ rpm for 30 minutes at a time on the road course). Thinking about the Ford Racing flow matched SVO red tops:
Ford Motorsports 30# Flow matched Fuel injectors
http://www.texas-speed.com/shop/item...d=222&catid=10
20-M9593B302F
$399.99
I'm probabaly also going to do some rockers, since my car has 60k miles, and I do 6ish HPDE's / year, which is pretty hard on the car.
Yella Terra Ultralite rockers
http://www.mphparts.com/mm5/merchant...Code=GTOLS1VLV
113-6645
$419.99
I didn't check on the sponsor status of the vendors I posted above, so mods please snip away if needed.
I'd appreciate some feedback as well. I don't want to overlook anything.
-Chris
113-134-1002
$7.49
19-941020
$273.98
20-M9593B302F
$399.99
113-6645
$419.99
-Chris
My shop recommended the following timing set:
Cloyes Hex-adjust-timing double roller timing chain.
http://store.summitracing.com/partde...rt=clo-9-3159a
CLO-9-3159A
$186.39
Feddback on it?
-Chris
CLO-9-3159A
$186.39
Feddback on it?
-Chris
The guy at TR gave me the wrong part number for the oil pump! Thanks for the catch guys, I called and correct that.
Yes, it's the ls2. And really that is enough for this cam (according to Dave at TR).
I also asked about the longer crankshaft pulley bolt, and he said I didn't need that. Is that what you're talking about trukk?
I'm also just doing the basic cam swap and I don't have the money to go with an UD pulley and other things that I wish I could. I figure this will bump up to close to 390rwhp and sound like an ls1 should.
Also, I'm glad I called back because they told me they wouldn't be able to get my headers/y-pipe in by xmas, so I went ahead and canceled that. I'll see if I can get it from Summit.
Wow, just called summit they matched the prices that Thunder Racing had for the headers and y-pipe AND gave me free shipping on the headers AND they're shipping out tonight. Summit rocks! I just hope TR comes through with all the other parts. They seemed to be a little scattered. Like the Patriot Gold Valvesprings he said should be there in week. I just hope that a week doesn't turn into a month...Crossing fingers...
Rarely. I try to keep it covered. I'm in college so I don't have to drive unless and emergency arises. Is there anything I can do that will help prolong the life of the headers (besides not driving in the snow/rain)?
sweet, I just recently ordered my cam from thunder as well and the dual extremes are on back order as well, but I was told they should be in by the time the cam gets back from being ground. So about a week or two :crosses fingers:
Yes, the LT choice was poor. However, spraying a few coats of VHT Flameproof Coating or wrapping them up will inexpensively prolong their life. I still recommend rarely, if ever, driving them in moist weather.
Do yourself a HUGE favor and get the Crane valve spring tool. It is available on the TR site. Its a lifesaver, changing the valve springs was by far the worst part about my cam install. Some other things you will want are red loc-tite, front timing cover gasket, and something to keep the lifters help up while the cam is out. If they fall down while the cam is out you are in a world of hurt and will be pulling the heads. TR also has those, but I have seen people use wooden dowel rods. I bought the tools from TR, they work VERY WELL. Just do your research before you get started and you should be fine. Pay special attention to the o-ring on the oil pump pickup tube. A lot of times it does not seat correctly and causes air to be sucked into the oil. You will get a nasty tapping from the lifters, happened to me and I had to go back in and re-do that o-ring.
