knock sensor
Old Dec 11, 2007 | 05:06 PM
trey1010's Avatar
Default knock sensor
My car has been pinging quite badly at lower RPMs since i have had it, today i realized that the check engine light does not come on when u first start the car, so figured the idiot I bought it from took it out.. I took it to advanced auto parts and had them run it to check it and sure enough it pulled knock sensor code, ugh... So how big of a deal is this? just change it out for a new one or what? how much does this part cost and how hard is it to install? thanks!
Old Dec 11, 2007 | 05:12 PM
Ericbigmac83's Avatar
The knock sensor is probably in the car and its just knocking. you need to figure out why its knocking. what gas do you run and what mods are on the car?
Old Dec 11, 2007 | 05:14 PM
trey1010's Avatar
The car is bone stock with 79,000 miles and I use 91 since its the highest around me.
Another thing is, should I replace the sensors and expect it to all be good, or find out why it is pinging in the first place? I am a little confused about this..
Old Dec 11, 2007 | 05:47 PM
trey1010's Avatar
another thing is i read that it is bad to drive much when these are bad, and since i had no idea my car was throwing a code until now i have driven almost 20,000 miles with this code i am guessing.
Old Dec 11, 2007 | 05:57 PM
well its not too hard to pull the intake and valley cover, but i seriously doubt the knock sensors were removed on a stock car. you can check to see if they are corroded though.
Old Dec 11, 2007 | 05:59 PM
trey1010's Avatar
well its not that i thought they were removed just maybe have gone bad? There is pinging so do i have a bigger problem?
Old Dec 11, 2007 | 07:16 PM
trey1010's Avatar
The car seems to run very good also, sometimes the idle is a little rough though.. I have been searching the forums and a question that I still have is could the pinging be caused by bad knock sensors?
Old Dec 11, 2007 | 07:35 PM
fastSS_LS1's Avatar
just replace the knock sensor. if that doesn't work, try the next easiest/smallest thing it could be.
Old Dec 11, 2007 | 07:38 PM
Tainted's Avatar
the knock snesor isnt bad to replace. I just put 2 new ones in mine today. once you pull your intake manifold off you see the 2 plugs for them. 22mm i want to say?
Old Dec 11, 2007 | 08:21 PM
trey1010's Avatar
Ok I will try and replace that 2morrow and just hope it solves the problem! One thing though doesn't the knock sensor keep the engine from pinging instead of making it ping?
Old Dec 11, 2007 | 09:34 PM
BLK02TA's Avatar
Mine were rusted to ****.
Old Dec 11, 2007 | 11:17 PM
trey1010's Avatar
yeah, one thing that is still making me wonder is, since i DO have pinging and i am throwing a knock sensor code, wouldn't that mean the knock sensor is working fine or not? On the other hand if it was working fine it would retard the timing to make it stop right? I am very sorry for all the questions but this is really concerning me and I am searching everywhere for these specific answers.
Old Dec 12, 2007 | 12:16 PM
trey1010's Avatar
bumpppp
Old Dec 12, 2007 | 12:20 PM
I'd pull the valley cover and check the knock sensors, shouldnt take you too long if you have any mechanical aptitude, just doing break the oil sending unit when you pull the intake (lift the intake straight up as high as you can, then pull it forward).
then replace them if they look corroded.
If they look fine then i would take the car to a tuner and see what he can find out.
Old Dec 12, 2007 | 12:34 PM
trey1010's Avatar
ok i am going to do that today! thanks!
Old Dec 12, 2007 | 04:18 PM
Soul TKR's Avatar
Here's mine at 80k miles... NOT GOOD
Old Dec 13, 2007 | 11:19 AM
Soul TKR's Avatar
updates?
Old Dec 13, 2007 | 01:07 PM
8a8mfh's Avatar
I'm working on mine right now. Heres the whole breakdown including part numbers and prices. https://ls1tech.com/forums/pcm-diagnostics-tuning/828629-got-dtc-need-advice-what-do.html
There is also a TSB out that has you silicone around the rubber boots so no more water will get in. The boots are oily so I cleaned them with brake cleaner first.
You will also find that the rear four intake bolts won't come out- they hit the cowl, take 4 one inch sections of rubber hose 3/8 or so, cut a slit down each one to put over the bolt so it stays held up.
I did a search and read a bunch of horror stories, mainly pinching the new wire under the intake or breaking the oil sender.
The oil sender is tricky because the brake booster vacuum nipple on the intake loops behind it so you have to lift it over the sender, during removal and installation.
And to be sure you don't pinch the wires just route them straight back, once the intake is set reach back and move them forward and backwards a little to be sure you're not pinching them.
Heres a link if you want to diagnose it http://www.gearchatter.com/viewtopic9363.php
Heres a link to the removal process http://www.ls1howto.com/index.php?article=18
Just follow the last link up to where they remove the knock sensors, YOU DO NOT NEED TO REMOVE THE VALLEY COVER.
One other thing, remove the fuel line so you don't need to bend it out of the way or remove the fuel rail. I did my disassembly last night and did not have the tool but I know what it looks like. I made one using the tube that comes with the silicone , cut it right at the threaded piece and make it about 1/2" long and put a slit in it. Put the big end into the line side of the coupling and push with some needle nose pliers, then pull the line off.
Old Dec 13, 2007 | 02:59 PM
trey1010's Avatar
Thanks A lot for all the replys!! I still haven't got around to it due to finals, but when i do i will update! Thanx again everyone for the help!
Old Dec 13, 2007 | 05:20 PM
BLK02TA's Avatar
Thats how my front one looked at 60k!
