The "Y Pipe" - a flawed design?
Old Jan 9, 2008 | 08:12 PM
  #81
ATLSS's Avatar
Originally Posted by Black02SLPSS
Also you need to remember that the further downstream the exhaust gases go the more they cool off and condense, thus requiring less space than they would coming right out of the collectors. Granted the exhaust gas will still be hot but not nearly as hot as when it exits the head and makes the short trip down the header. Im not trying to state that one is better than the other or start an arguement just pointing that out.
Good point. Thanks for the input...
After a few more discussions with American Racing Headers and Mufflex, I've decided to go with a 3.5" merge and catback...
So, the headers, y pipe and catback are all on order... I'll have a full write-up with pictures, etc as soon as it's all installed...
I can't wait!
Old Jan 9, 2008 | 10:44 PM
  #82
dug's Avatar
dug
If you want it quiet as possible magnaflow makes a 3.5" muffler with 5x11x22" case.
Its nice to see mufflex finally using a magnaflow muffler
Old Jan 9, 2008 | 10:53 PM
  #83
ATLSS's Avatar
Denny at Mufflex mentioned that the muffler would be oval... so this may be the muffler I'm getting... ?
Old Jan 9, 2008 | 10:55 PM
  #84
Grifter's Avatar
I can't wait!
Ok, now you'll really have my exhaust.
They have always been a Magnaflow dealer. But since people only saw Spintech or Flowmaster as an option, those became the most popular ones used. They'll use what ever muffler you want.
Old Jan 9, 2008 | 10:57 PM
  #85
Grifter's Avatar
It's going to be the same muffler I have.
http://www.magnaflow.com/02product/s...ne=main&id=568
Old Jan 10, 2008 | 04:25 AM
  #86
NSTY WS6's Avatar
Your paying a pretty penny for that exhaust!
I saw a set of ARH 1 7/8 stepped to 2" into 3.5" collector, then 3.5" Y that after the hvmc in the Y it went right into a 4" pipe. This is going to a 4" cut out and back to a 3.5 inch cat back. the 4" pipe actually deepens the exhaust note, and takes any rasp it might have out. Cut-out sounds mean too.
All stainless. It was absolutely the best work I've ever seen.
Old Jan 10, 2008 | 05:42 AM
  #87
ATLSS's Avatar
That's a good looking muffler.
Denny mentioned that the fitment is better with this muffler over the round Magnaflow....
Old Jan 10, 2008 | 05:44 AM
  #88
ATLSS's Avatar
That must have been for a larger stroker motor...sounds like an awesome setup none the least. It's actually the same size setup a buddy of mine is running, except for he has a 4" catback and no cut out...
I'm going with the 1-3/4" primary w/ 3" collector, dual 3" catted y pipe to 3.5" merge, 3.5" catback...
I sure hope my car sounds great and goes faster...
And I agree that American Racing Headers makes some great looking stuff...and no it's not cheap, but you get what you pay for...
Old Jan 10, 2008 | 10:10 AM
  #89
ls2 bait's Avatar
post pics of it when its done. cant wait to see it.
Old Jan 10, 2008 | 10:34 AM
  #90
Jordan S.'s Avatar
As if there wasnt enough of them already haha
3in Y, 3in I pipe, 3 in dynomax dumped is how I'm going.
Old Jan 10, 2008 | 11:17 AM
  #91
XtraCajunSS's Avatar
Keep in mind that I am no mechanical engineer, and certainly not a seasoned exhaust designer/fabricator... but here is a GENERAL idea as to the surface area of each of these pipes/setups:
Single 4" pipe = 12.56 sq. in.
Dual 2.5" pipes = 9.81 sq. in.
Dual 3" pipes = 14.13 sq. in.
So with this being said, the dual 3" setup has marginally more surface area than a single 4". But, do not let this mislead as I'm sure there are many other factors that affect the end result - horsepower.
A single 4" will generally flow better than two 3" tubes due to the greater frictional losses from increased inside surface area.
Old Jan 10, 2008 | 01:19 PM
  #92
DrkPhynx's Avatar
Very interesting discussion, and indepth, so I hope you guys don't mind a n00b-ish question, but, don't most Y-pipes connect on the side of the car (rather than the center)? Wouldn't that lead to un-evenness between the 2 sides of the engine (as one side has a shorter, straighter path than the other)?
Or is it just so minute it's insignificant?
Old Jan 10, 2008 | 05:21 PM
  #93
ATLSS's Avatar
I've studied hydrology and I can see your point if we were talking about water and a not-so-smooth surface...
But we're talking about air and a smooth pipe surface, so I'm not sure this is a valid argument...
But, I'm always open to learning more if you have more info to back it up...
Thanks
Old Jan 10, 2008 | 05:22 PM
  #94
ATLSS's Avatar
If I'm not mistaken, the y pipes are fairly close in length and meet together near the center of the car... so I'm not sure that the difference in length (which may be none or very little) has any affect on performance one way or another...
Someone correct me if I'm wrong please.
Old Jan 10, 2008 | 05:37 PM
  #95
Grifter's Avatar
From all of the threads and information I've read on y-pipe setups, it seems like the quality of the merge is the biggest concern. You don't want the 2 exhaust streams smashes into eachother and then going into the i-pipe. That's why the Flowmaster merge is so popular, the streams run parallel, then join. Same goes for the merge ARH uses.
Old Jan 10, 2008 | 06:31 PM
  #96
Black02SLPSS's Avatar
Or the one that Patrick G uses. Thats the one I would like to get ahold of.
Old Jan 10, 2008 | 06:35 PM
  #97
Viper's Avatar
I thought he used a flowmaster merge?
https://ls1tech.com/forums/generation-iii-internal-engine/732392-recipe-500-rwhp-heads-cam.html
Old Jan 10, 2008 | 06:42 PM
  #98
Grifter's Avatar
https://ls1tech.com/forums/showthread.php?t=732392
On his car I think he uses a Burns merge.
Old Jan 10, 2008 | 06:47 PM
  #99
SladeX's Avatar
I'd check around for a muffler shop that can do true duals, even though I live up in Canada now, I was able to find a shop that did my stainless steel true dual mandrel bent 2.5 inch over the axle mufflers from cats to tips for $400. I provided the mufflers and tips.
So it doesn't hurt to ask around. At some shops I was quoted as high as $1400 to do the same damn thing.
If you do go the y-pipe route, the merge of the y is key. You need to merge it in such a way that the pulses don't interfere with each other. The key to this is to merge them in such a way that one pipe is not significantly longer than the other when they meet. Second is to use a merge similar to that by flowmaster. Minimize the bends as much as possible as well. The shorter the path out, the better.
  #100
Viper's Avatar
Step up gentleman, $190 for a merge:
http://www.burnsstainless.com/MergeC...into1base.html
