The "Y Pipe" - a flawed design?
Old Jan 10, 2008 | 06:59 PM
  #101
dug's Avatar
dug
Originally Posted by DrkPhynx
Very interesting discussion, and indepth, so I hope you guys don't mind a n00b-ish question, but, don't most Y-pipes connect on the side of the car (rather than the center)? Wouldn't that lead to un-evenness between the 2 sides of the engine (as one side has a shorter, straighter path than the other)?
Or is it just so minute it's insignificant?
an equal length ypipe would be ideal, but not practical. Supposedly the rasp of the ypipe is from the unequal lengths.
Old Jan 10, 2008 | 07:17 PM
  #102
Grifter's Avatar
I thought some of the rasp was caused by a poorly designed merge.
Old Jan 10, 2008 | 07:37 PM
  #103
dug's Avatar
dug
Thats part of the cause.
Equal length tubing will provide a smoother tuned sound. Checkout ls1sounds and compare the sounds of different headers. The slp equal length headers sound the smoothest and the macs are the harshest.
Old Jan 10, 2008 | 07:47 PM
  #104
JL8Jeff's Avatar
That doesn't make sense because with cats the rasp goes away. LT1 cars use the same y-pipes without the rasp. That tells you it's really caused by the exhaust/head layout of the LS1 vs the older style small block.
Old Jan 10, 2008 | 09:00 PM
  #105
Grifter's Avatar
This is just what I've read. Cats reducing rasp doesn't suprise me, it's a restriction in the exhaust, I can see it reducing noise and rasp.
Old Jan 10, 2008 | 09:05 PM
  #106
Black02SLPSS's Avatar
I believe Patrick G uses a custom merge from LG. It may be in "the recipe for 500 rwhp"
Old Jan 10, 2008 | 10:35 PM
  #107
Grifter's Avatar
In his For Sale thread it says Burns.
Old Jan 10, 2008 | 11:19 PM
  #108
dug's Avatar
dug
http://drgas.com/store/product.php?p...6&cat=1&page=1
This merge is similar to headers with hvm collector qtps use.
I think PatG used the burns merge with a 3" to 3.5" transition as an expansion cone. I could be wrong
Old Jan 10, 2008 | 11:26 PM
  #109
GMmexican's Avatar
If it wasnt for the california smog ***** id be running an un-catted 3in true duals with dynomax bullets
Old Jan 10, 2008 | 11:54 PM
  #110
dug's Avatar
dug
If u lived in chitown u could run open headers
Old Jan 11, 2008 | 02:39 AM
  #111
GMmexican's Avatar
really? thats legal over there?........the cops over here are super strict, its like communist russia over here
sorry
Old Jan 11, 2008 | 03:30 AM
  #112
dug's Avatar
dug
I didnt mean any disrepect or wise guy attitude. chicago area only checks for codes. If u show up with open headers, as long as the computer sez everything is ok. theres nothing they can do.
Old Jan 11, 2008 | 11:01 AM
  #113
JL8Jeff's Avatar
Actually, that's wrong. It's a federal law that you can't alter emission's equipment. That means no removing emission equipment and you also can't move the location of it. So removing cats and AIR stuff is illegal in every state. Some states choose not to care at the moment, but eventually the federal gov't will take away their highway funds until they start enforcing stricter inspections like we have here in NJ. Obviously people get away with running longtubes with no cats or AIR. But it's probably just a matter of time before that changes.
Old Jan 11, 2008 | 03:03 PM
  #114
dug's Avatar
dug
Im sure there are laws but here they dont check.
Old Jan 11, 2008 | 04:34 PM
  #115
99mongooSS's Avatar
here in Texas we tend to be able to get away with anything! God I love my state!
Old Jan 11, 2008 | 04:57 PM
  #116
ATLSS's Avatar
Do you guys mind making you own thread to discuss the legalities?
Thanks
Old Jan 18, 2008 | 05:37 PM
  #117
98Aggie's Avatar
Moderator
Originally Posted by ATLSS
I've read most of Patrick's posts... he's a smart guy...
Wasn't Patrick's y pipe merge 4"? What catback is he using again?
The y-pipe I built for Patrick is 3" off the LT. Then into a 3" to 4" burns merge collector (from LG motorsports). Then a 4" QTP cut-out and then reduces back down to 3". Muffler is the Dual Dual. Tucks up under the car with no cleareance issues and no bagging.
We dynoed the car with 20" extensions on the car and with the new Y and lost no hp or tq (picked up mor tq down low) then when went through the dual dual we lost 9hp.
