The "Y Pipe" - a flawed design?
Old Jan 5, 2008 | 09:19 PM
ATLSS's Avatar
Default The "Y Pipe" - a flawed design?
From what I have read, most y pipes merge into a single 2.75" diameter... and please correct me if I'm wrong, but cramming +500hp through this diameter isn't efficient by any means...
So, my question is this - do I have a custom fabricated y pipe merge of at least 4", then attach a mufflex type 4" catback for optimum flow?
I mean, from what I have seen the vettes don't have this issue of merging the exhaust...
And I can't believe that the F-body has been out for over 15 years and no one manufacturers a bolt-on stainless "true dual" setup... which is horse **** IMHO... and it makes me want to buy a vette or a 1st gen Camaro... ha.
Thank you and drive through.
Old Jan 5, 2008 | 09:28 PM
Tainted's Avatar
a Y pipe can flow VERY well with the use of a good merge and proper sized pipes. Patrick G did a write up on how to make 500hp and used a Y pipe
and Bassani makes a true dual set-up thats stainless also and LPP is making a stainless TD system like TSP's
Old Jan 5, 2008 | 09:33 PM
pitbull14218's Avatar
I would like to see TD Over the Axle. That would be expensive i bet!
VIPRETR2's Avatar
I put a cutout behind both header collectors. No worrying about fitment, ride height, extra weight for "true" duals, flow of a single 3" pipe, or fitting a monster 4" pipe (which I have done in the past). Add electric cutouts and your set. Seemed like a pretty straight forward solution to me, I'm surprised you don't hear about it more.
Larry
Old Jan 5, 2008 | 09:35 PM
ATLSS's Avatar
Yeah, and the guy had to hack on it and modify it to have a 4" merge IIRC...
Why doesn't someone make a bolt on exhaust for us?
When I say true dual, I'm not talking about dumped under the car...
Old Jan 5, 2008 | 09:37 PM
ATLSS's Avatar
Larry
I'm sorry, I don't care to run my car "uncapped"... it's a street car, not some '70 model rusted Mopar with 22" slicks and a "cage"...
Old Jan 5, 2008 | 09:39 PM
xXSilencerXx's Avatar
Bassani does and I think I've seen TSP too.
Old Jan 5, 2008 | 09:42 PM
ATLSS's Avatar
TSP is dumped under the car... which any yahoo at a muffler shop can do...
Tainted's Avatar
like I said Bassani makes an over axle 2.5" true dual set-up but its designed for stock manifolds but tis easily modified to fit longtubes
Old Jan 5, 2008 | 09:43 PM
94BlackSSClone's Avatar
dude, I don't know what you're thinking. TSP make some nice true duals though they are dumped. Bassani make a td system out the back....if you're saying all this and you have a 500+hp car, you should probably switch to duals instead of dealing with a y-pipe anyways...So fork out the money and do a custom setup.
Old Jan 5, 2008 | 09:47 PM
VIPRETR2's Avatar
LOL, hence the electric cutouts. If there was a serious demand for a dual system it would be on the market. I had a nice 4" Mufflex with a dual 3" into 4" flowmaster merge collector from the Y. All it takes is time and fab work. I loved the sound of the 4" FLowmaster as well but the system was heavy as hell and a bitch to fit. Fitting a dual exhaust will be a pain in the *** to the fourth power.
Old Jan 5, 2008 | 09:48 PM
ATLSS's Avatar
TSP is dumped, no thanks.
Bassani is the only other bolt-on option and it's made for the stock manifolds/cats...
So, there is NO company that MAKES a stainless header-back dual exhaust that exits at the rear bumper??
Old Jan 5, 2008 | 09:50 PM
Tainted's Avatar
only custom made ones
Old Jan 5, 2008 | 09:53 PM
ATLSS's Avatar
Correct.
This is the only guy I found on this forum that had a custom setup made by ARH - http://www.fquick.com/garages/viewga...ewimg&id=26797
My question still stands though - why doesn't anyone make a true dual exhaust that connects to headers and exits at the bumper??
Old Jan 5, 2008 | 09:58 PM
Tainted's Avatar
because
EVERY car is different. it would take so much time and money to fab up a system that would fit but would still require so much adjusting it wouldnt be worth it. these cars werent made to have TD's
Old Jan 5, 2008 | 10:01 PM
ATLSS's Avatar
i.e., a flawed design.
Old Jan 5, 2008 | 10:13 PM
JL8Jeff's Avatar
A true dual exhaust won't make any more power than a good single intermediate pipe setup. There isn't much room for dual 3" over axle setup and a single 4" will make plenty of power. No company is going to make a 3" dual over axle setup because they can't gaurantee it will fit and it's really overkill unless you have a 800+ hp race car. How much power are you expecting? A 2-1/2" dual exhaust like the Bassani will make quite a bit of power to begin with. You could easily get a shop to adapt it to headers. I agree that the "dual exhaust" being sold with dumps is not even worth considering unless you like to sound like an old pickup truck with rotted out mufflers.
Old Jan 5, 2008 | 11:08 PM
we all know it's a flawed design, we all wish gm had made them a td car. Why didn't they? I dont know, but they should have. We all think they should have since the day they were released most likely. So the "flawed design" is something every car will have. Not many cars are ABSOLUTLY perfect. Every car has something that could be a little better. Hence, the world of aftermarket parts and custom fab work
qwikz28's Avatar
why is that a flaw? i think cost efficient is the correct term. if you can make the power with one pipe, then why 2? i bought a true dual setup and eventually reverted back to the y-setup. for me, the benefits don't outweigh the cost
Old Jan 5, 2008 | 11:28 PM
Zero4488's Avatar
Restricted User
I believes Kooks makes a "big" Y pipe that goes along with their race headers....
