Back Firing
Old Jan 14, 2008 | 08:48 PM
TFRO's Avatar
Default Back Firing
2 Weeks ago I put a set of Pacesetter long tubes, 3 inch Y and a single chamber flow on my 99 Z, I also dumped it infront of the rear axle. Now the car backfires when I get on the gas and then let off, kind of embarassing when it does it, will running the pipe over the axle help or is it my muffler? Any help please.
Old Jan 14, 2008 | 09:18 PM
g-ryde1's Avatar
mine does the same thing, did the same with my flowmaster before the header install
wondering the same tho
Old Jan 14, 2008 | 09:23 PM
RedRallyeZ's Avatar
mines run over the axle and still pops, but like you said, only when i compression brake. its not that bad if you ask me...
Old Jan 14, 2008 | 09:33 PM
SOMbitch's Avatar
If you didn't get a tune you may get a backfire cause it is running rich and dumping fuel. Some chambered mufflers just pop on deceleration (my single chamber does). does it sound like a gunshot (backfire) or a little less intense (normal).
Old Jan 14, 2008 | 09:37 PM
TFRO's Avatar
I would say it sounds more like a gun shot on hard accel and just little pops on normal driving.
Old Jan 15, 2008 | 04:51 AM
BLACK2001SS's Avatar
I'd cleen out your MAF (stp MAf cleener) and check to make shure your plug wires are all connected good.
Old Jan 15, 2008 | 10:14 PM
penningta's Avatar
Are you still running AIR because it woud be dumping air and fuel into the exhaust and getting hot and igniting in the exhaust
Old Jan 16, 2008 | 04:21 PM
TFRO's Avatar
nope got all the air / egr deleted
