Overdrive crank pulley?
Old Jan 19, 2008 | 05:35 PM
yotaman96's Avatar
Default Overdrive crank pulley?
Does anyone produce an overdrive (as in larger) crank pulley for the fbody?
Old Jan 19, 2008 | 05:55 PM
bww3588's Avatar
why would you want that? to take HP away?
Old Jan 19, 2008 | 05:56 PM
yotaman96's Avatar
Just in case I decide to run more boost on my maggie without putting a very small pulley on the charger.
Old Jan 19, 2008 | 05:57 PM
bww3588's Avatar
gotcha, i dont think they do....
Old Jan 19, 2008 | 07:02 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I don't think they do for the accessory drive...guys that run Prochargers have options, but if the Maggie runs off of the main belt (and I think it does), I think you are pretty much set at 7.5" max.
Old Jan 19, 2008 | 09:07 PM
BadMonkey's Avatar
I have heard of one out there but I cannot remember where I found it. But it may have been for the C5 acc. drive though not the F Body. Best thing would be to change the rear pullies if I find where I saw it I will let you know.
Old Jan 19, 2008 | 09:27 PM
BadMonkey's Avatar
ECS has one for thier setups. You will have to call them though its not on thier website. Do we use a C5 crank pulley don't we? I cannot remember since I had Ed do the initial install. I cannot remember if the f bodies is the same or not. If we do then using ECS's OD pulley should work.
Old Jan 19, 2008 | 10:04 PM
MeentSS02's Avatar
F-body and Y-body accessory drives are not the same...I do know that much. I think they use different spacing...
Old Jan 19, 2008 | 10:43 PM
yotaman96's Avatar
Yeah, it's different spacing. I think the ECS pulley for the vette is like $500. That's a lot for a pulley.
Old Apr 10, 2008 | 04:49 AM
yotaman96's Avatar
After researching, overdrive pullies are made for the gto. Fbody's and GTO's have the same pulley offset. If anyone wanted an overdrive crank pulley for their fbody, they could just order one for a gto.
