temp above 210 degrees ?
Old Feb 11, 2008 | 10:16 PM
smokingfastws6's Avatar
Default temp above 210 degrees ?
so i drive my car a good distance on a trip and my temp goes above 210 not much but it does will that hurt anything ? my fans keep it at 210 because they kick on but i am about to put a lower thermostat any ideas ?
Old Feb 11, 2008 | 10:50 PM
ta_06374's Avatar
Thats normal opperating temp. but its too hot for most people so they put a 160 stat in and tune the fans to come on at 180.
Old Feb 12, 2008 | 12:19 AM
ApexVIII's Avatar
yea thats about normal,
Old Feb 12, 2008 | 08:59 AM
jimmyblue's Avatar
Moderator
The thermostat will help you none because it's full
open already. It's the fans and radiator that set the
upper temperature, the thermostat only sets the
low end. It has no authority because nobody's "got
its back" (not enough cooling airflow w/ fans off).
So do not waste your time and money on the "160"
thermostat. Just get the fans programmed right.
Old Feb 12, 2008 | 10:36 AM
okay thanks for the info i am still going to do the thermostat because i have it already and i dont want any chances on the old one sticking but i am going to get the fans tuned
Old Feb 12, 2008 | 10:51 AM
TheLS1Kid's Avatar
The temp gauges on 1999-2002 Camaros and Firebirds are dummy gauges. If you are seeing 210 that is not the actual temp. Only 1998 had a real working gauge.
If it stays at 210 that is normal. On 1999-2002 it only moves if it is overheating.
So even if you put a 160 thermostat in, the gauge will still read 210 on a 1999-2002.
Old Feb 12, 2008 | 11:23 AM
00_transam_vert's Avatar
Originally Posted by TheLS1Kid
The temp gauges on 1999-2002 Camaros and Firebirds are dummy gauges..
Care to elaborate?
Old Feb 12, 2008 | 11:50 AM
waldershrek's Avatar
^^^Um....I think he pretty much did in the same post
Old Feb 12, 2008 | 12:54 PM
No he didn't, All he said was that they were dummy gauges and that they don't show the real temp. I was curious if they just showed a constant value when at operating temp or if they just showed X# of Degree's; lower or higher consistently.
Old Feb 12, 2008 | 02:20 PM
jimmyblue's Avatar
Moderator
They move by "notches" to points picked by the
PCM. There is no particular calibration and not any
continuous, linear indication of real temp. The ECT
(stock) for kicking on low speed fans is 226F (off
at 219F).
Old Feb 12, 2008 | 05:10 PM
TheLS1Kid's Avatar
at 219F).
Yes sir.
To summarize it, on a 1999-2002 F-body the temp gauge will read 210 at operating temp unless the car is overheating.
Old Feb 13, 2008 | 09:20 AM
ncz28ragtop's Avatar
yeah i have a 98 and it reads about 180 goin down the road normally
Old Jul 12, 2008 | 10:46 AM
JamMasterJ's Avatar
Default 2000 C5 Fan Reprogram
Can a dealer reprogram the PCM to cut the fans on earlier. Or is this a mod of some kind done through aftermarket means. Thanks
Old Jul 12, 2008 | 11:26 AM
Weezzer's Avatar
Its my understanding the gauge (except on '98's) will read 210 degrees for the temperature range of 180-226 degrees, once the temperature goes beyond 226 the gauge will show the actual temperature.
Tis' why the gauge will jump up or down really quickly at times - if your car tends to overheat.
