Do balancers go bad?
Old Feb 12, 2008 | 07:06 PM
turbopaez's Avatar
Default Do balancers go bad?
This is my first camaro and wanted to know if these balancers go bad like the mustangs do. I am asking cause I get a vibration right at 2200rpm and up in park. Thanks for all the help.
Old Feb 12, 2008 | 08:13 PM
socmguy's Avatar
Restricted User
I don't think I've ever heard of a balancer going bad but I could be wrong.
Old Feb 12, 2008 | 09:10 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Every once in a while I'll hear Corvette owners post up about a failed balancer...search around and I'm sure you'll see what I'm talking about.
Old Feb 13, 2008 | 08:07 AM
turbopaez's Avatar
I havent check it out yet but would you be able to tell if one is bad?
Old Feb 13, 2008 | 09:44 AM
MeentSS02's Avatar
Look at it while it is running...if it is wobbling like a drunken *****, it's bad.
Old Feb 13, 2008 | 10:20 AM
RooRnZ28's Avatar
****... mine wobbles a little... looks like its time for a new one!
Old Feb 13, 2008 | 10:52 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
The wobbling could be that it's not seated properly. Check that first.
Old Feb 13, 2008 | 02:20 PM
turbopaez's Avatar
Thanks guys for all the info.
Old Feb 13, 2008 | 05:43 PM
DaveX's Avatar
It could go bad and cause a problem, but it's unlikely. And it's not really a balancer because these motors are internally balanced. It's just a pulley and vibration dampener.
Old Feb 13, 2008 | 06:46 PM
turbopaez's Avatar
I checked it and seems to wobble a little, could that casue the vibration cause it doesnt look like it wobbles much. I was going to get a pulley any way so I guess I will find out.
Old Feb 16, 2008 | 12:45 AM
quadd2244's Avatar
Mine had a slight wobble in it causeing it t have a horrible belt squeal. I changed almost all the other pulleys along with a new belt and even cut the a/c belt off and still had a bad squeak. So I changed up to a U/D pulley and 10,000 miles later no squeak so mine had enough of a wobble to cause a horrid sounding squeak
