425-450 Rwhp
Why running only a 14.11? How is your traction in that truck?
along the lines of what Trap said....the way you spend the money will determine how tame the engine is.
bigger cam with cheaper heads will make the power...at the cost of driveability
milder cam with GOOD heads will make the power...with good driveability...at the cost of $$$$
a pretty tried and true combo would be a cam along the lines of the TSP Torquer 2, or Futral F14....with a set of 5.3L heads or LS6 heads speced out to get compression up to 11:1
and another thing to realize...is the rest of the drivetrain that you'll be making this power through. a h/c combo that makes 450rwhp on a manual T56 trans and 10bolt will be hurting to make 425rwhp through a high stalled A4 with a 12bolt.
so that's part of the equation you havn't really explained to us.
This will make good power under the curve, and perform well at the track. If you need faster get a bottle
Go with Futral Cam, and LS6 Intake or go bigger and get Fast 90 Intake, and dont forget a good set of stage 2 or better heads. Good set of LT Headers, and a set of True Duals.
I know someone mentioned drivetrain. I will be beefing up the 4l60e and get the stall to match the cam. as far as the rear end, i'm waiting until the stock 10 bolt blows so i can get a currie 9".
