header installation
Old Feb 13, 2008 | 01:48 PM
snake3126's Avatar
Default header installation
does any one have a step by step header installation either vid, or read through
thanks
Old May 19, 2008 | 12:13 AM
ozzman98's Avatar
i don't really know of any step by step but when i did mine i had to remove the plugs, starter, alternator and a few other things. it isn't fun. if you have a lift i reccomend using it otherwise it will be difficult. it's a tight fit. it also depends on what kind you get. mine are slp lontube
Old May 19, 2008 | 01:09 AM
Kingc8r's Avatar
Nothing on LS1howto or install university. It wasn't that hard really....did you try a search? Let me see if I can find anything
Old May 19, 2008 | 01:13 AM
Kingc8r's Avatar
http://www.bfranker.badz28.com/fbody/exhaustday.htm
Old May 19, 2008 | 04:28 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Pretty easy and straightforward. pull the plugs and jack the car about 4 feet in the air.
Old May 19, 2008 | 09:13 AM
CAMAROZ28SS's Avatar
you dont need to have it 4 feet in the air. i used a floor jack as high as it would go which is probably 2 feet and had no problems.
and to answer your question. its really straight forward. pull the old stuff of and put them new stuff on
Old May 19, 2008 | 09:24 AM
ballhawkdawk's Avatar
http://camarossworld.com/Technical/exhaust.asp
many different instruction guides
Unplug the battery, have the AIR and EGR fittings if necessary. Take off the coil packs. Take off plugs and wires (replace with fresh ones at the end). Take off all the old manifold/exhaust/y-pipe, save the cats and sell them. PB blaster helps break the old bolts loose. Use some kind engine assembly lube on the header bolts. Bolt up the headers, fresh plugs, fresh wires, coil packs on, battery connected.
I'm pretty sure this is exactly what I did. I had the front jacked up.
Old May 19, 2008 | 09:41 AM
dutinsss's Avatar
i jacked the front and rear and put them as high as i could on jackstands and shoved ramps under the front tires just to be safe. i unbolted the blaster packs except for the far back bolt because i couldnt get to it and layed them to the side but in retrospect, i wish i would have completely removed them, it'd make it a ton easier. then remove the plugs/wires, unbolted the starter, but let it hang from the wires and rest on a bucket. while your down there, unplug the O2 sensors. remove the dipstick by unbolting it and pulling it out. then unbolt the manifolds from the exhaust, then unbolted the manifolds from the heads. put your new plugs in. after that, slide the headers in from the bottom and have somebody hold them up from the bottom and start bolting them up. take your time and make sure not to crossthread them. then just start bolting everything back up. if all i was doing was the headers, i could have finished in a day but i did motor mounts as well and had some complications with them so it took 2. take your time and its pretty straight forward. also, PB blaster is your friend. soak manifold to head bolts, and manifold to exhaust bolts and it'll help you out a lot. and when you reinstall the dipstick, have one person under the car lining it up and the other pushing it down, from the top. hope it helps!
 Michael S. Palmer
Old May 19, 2008 | 03:44 PM
hlaalu's Avatar
take off the coils, remove plugs, remove air and egr, remove y-pipe, take out the two bolts holding the starter (just let it hang or rest on something), then pop off the old pos manifolds.
Old May 26, 2008 | 04:32 PM
Ripper415's Avatar
on the 01-02's it's like impossible to remove the coil packs cause it's just one big unit, not several individual ones. the best you can really do is get the front bolts off and then angle the off as much as you can with the rear bolt on. that's the best i could get when i changed my plugs, and i STILL scraped the **** outta my hands. i dont know how the heck anyone can get the back bolt off. i even used a swivel extension on the ratchet and still no luck. these cars are a pita to work on.
Old May 26, 2008 | 04:45 PM
mycamaroSS's Avatar
very good info here...gotta look at these once i get home and start my full bolton installs
