Fast 90 installation
Old Feb 16, 2008 | 09:05 AM
1BDBOTI's Avatar
Default Fast 90 installation
Anybody have any pics of FAST 90 install. I bought intake, TB, and fuel rails with fittings. What eles will i need to finish project. Other fittings, fuel lines, fuel pressure regulator, ???????? HELP
Old Feb 16, 2008 | 09:47 AM
Disturbed Bird's Avatar
what fuel rails did you buy?
whats else is done to the car?
with the fast 90 you will need to buy the fast manifold gaskets. if you bought the fast throttle body return it and get anything but that one
Old Feb 16, 2008 | 09:51 AM
00bluews6's Avatar
what year is your car
Old Feb 16, 2008 | 10:25 AM
davered00ss's Avatar
Moderator
found this on the board
kit from Nasty performance.
rails from fast wi fittings
Mine have been in the box for over a year.
Old Feb 16, 2008 | 10:46 AM
1BDBOTI's Avatar
i got a FAST 90 intake Fast fuel rails and FAST 90 TB.
The car is a 2002 SS
Old Feb 16, 2008 | 10:50 AM
1BDBOTI's Avatar
I have torn the motor down new rings, bearings, gaskets, MS4 cam, springs, pushrods, lifters, 410 gear with auborn unit, gonna buy new trans with a 2500 stall con., long tubes, tourqe arm, cut outs, x-pipe
Old Feb 16, 2008 | 11:05 AM
you need to get rid of that throttle body it sticks. you need to get something else. i would get a NW 90MM.
you will need bigger injectors, a 12bolt rear end, yours will break soon.
i dont know about the fast rails but you may need a fuel pressure regulator. someone else might chime in on this statement
Old Feb 16, 2008 | 12:03 PM
1BDBOTI's Avatar
what size injectors????????What kind of injectors, wheres the best place to bye them??? I plan on buying a moser 9 inch later, daveredooss,,,, i cant find that nasty performance kit on there web site???? Do you maybe have a parts list of what fittings and size of fuel line??? Thanx
Old Feb 16, 2008 | 02:07 PM
http://www.nastyperformance.com/FuelSystem.html
scroll down for the kit
Old Feb 16, 2008 | 03:41 PM
well i hope your going to be doing heads with that cam, or you might be a little disapointed with the results. but if you were to do heads with it i would say go with 42lb injectors from harris speed works they are on sale
http://www.harrisspeedworks.com/shop...cat=331&page=1
1BDBOTI's Avatar
what size injectors
Old Feb 16, 2008 | 06:54 PM
globe's Avatar
i dont think 2500rpm stall is a good idea on a with the MS4 prob want a stall around 4k to really wake that cam up. just my 2 cents
Old Feb 16, 2008 | 07:04 PM
slowandrichws6's Avatar
i agree, thats a high rpm cam therefore if you want to get the most out of it i would go 4000 stall at the minimum.
Old Feb 16, 2008 | 07:22 PM
1BDBOTI's Avatar
You are right but this is going to be a street car, i have a full chassis 92 rs camaro i drag, its a beast
Old Feb 16, 2008 | 07:23 PM
1BDBOTI's Avatar
is the head porting worth the money
Old Feb 16, 2008 | 08:54 PM
LS1-NAVY's Avatar
was gonna say the same thing
Old Feb 17, 2008 | 11:01 AM
no buy a good set of heads: trickflow, etp, afr
Old Feb 17, 2008 | 12:57 PM
00bluews6's Avatar
what size injectors
i got the #42 from racetronix and am very happy with them and they are on sale now http://www.racetronix.com/17113813.html
u might wont to get a 255 in tank pump dep. on what your fuel psi is if you end up doing that u might as well get the racetronix hot wire kit
