3" to 2.5"
Old Feb 19, 2008 | 02:42 PM
jetlag's Avatar
Default 3" to 2.5"
Right now I have Pacesetter LTs into their offroad y-pipe with a Dynomax bullet welded on to the end with a turndown. I want to get rid of the turndown and have some pipes coming out the back, but no one around here can mandrel bend 3" pipe, they can only crush bend. They say I should just buy a catback....
Would welded 2.5" onto the end of my 3" Y-pipe/Bullet cause a noticeable drop in power? Or not enough to worry about?
Thanks
Old Feb 19, 2008 | 02:50 PM
Segselah's Avatar
I would just get a full 3" cat-back and ditch the bullet
Old Feb 19, 2008 | 03:08 PM
jetlag's Avatar
Wow, thanks, that was exactly the answer to my question!
Old Feb 19, 2008 | 03:11 PM
Segselah's Avatar
Look, downsizing the pipe is of course going to mess with your flow, will it be noticeable? I dunno. Is it worth it? I would say definitely not. Why would you want to do anything that would decrease your power? Why don't you just unplug a spark plug wire while your at it. It will probably decrease your power, but it would sound cool, and that's worth it.
Old Feb 19, 2008 | 04:45 PM
radz282003's Avatar
Old Feb 19, 2008 | 06:56 PM
Atver300's Avatar
Look on ebay for someone selling a bunch of 3" mandrel bends in a box. Ive got paceseters and a y and a 1 chamber flow with a dump but im fixin to build true duals with a 2.5" mandrel bends i bought on there for about $40 and i remeber seeing some 3"
Old Feb 19, 2008 | 08:02 PM
99Hawk262's Avatar
I think APE here in Jacksonville can hook you up....if it's worth the 2-hour drive for you. If you need more info, let me know and I'll talk to them for you.
Old Feb 19, 2008 | 09:43 PM
jetlag's Avatar
Hey, definitely not worth the 2 hour drive..haha
Old Feb 19, 2008 | 10:14 PM
SVThis's Avatar
ok...i know this is NOT the answer your lookin for, but its the best answer possible...get a catback or buy/build a TD system...good luck with whatever you decide
Old Feb 19, 2008 | 10:15 PM
jetlag's Avatar
Yeah, I just don't want to spend $400 on a catback system when all I want is my Dynomax Bullet in the stock muffler location..haha
I want to leave the turndown on the Bullet and just mount the muffler sideways in stock location. I don't care about having tips, I want it hidden...so no need to actually buy a catback.
Old Feb 19, 2008 | 11:10 PM
RE AND CHERYL's Avatar
The tail pipes are not as critical as the pipes before the mufflers. The mufflers cause backpressure and lower the exhaust gass velocity significantly. I'ts doubtfull you would notice a rear difference on the dyno and I'd bet money you'd never feel it.
Re'
Old Feb 19, 2008 | 11:17 PM
jetlag's Avatar
Re'
Thanks
