True Duals Cost POWER!?!?!??
I find it sad that you're trying to create an uneven argument - as in a bad X-system compared to a nearly perfect y-system.
Here is a picture of a good X-crossover vs a BAD X-crossover so you can see what I'm talking about.
BAD:
GOOD:
great way to practice what you preach lol
here's the rough guide for ideal systems, this doesn't take into account **** poor design decisions. Taken from our exhaust sticky. How about we just leave it at sound preference because quite honestly, you don't have to go crazy big for either setup to achieve a good supporting exhaust setup. Just go with your budget and build it right.
"Hey guys I just got done reading a good article in the May 2005 issue of Popular Hot Rodding Magazine. The article was written by David Vizard who seems to be one of the most accredited and respected people in the automotive performance world. In the article he stated that CFM is a great way to help develop a zero loss exhaust system. For zero loss a exhaust must flow 2.2 CFM per horsepower(This means less than 1% of total power produced by the engine is lost due to back pressure.). From reading the article I think that a lot of people that see gains when going from a 2.5” exhaust system to a 3” dual system see them because the muffler on the 2.5” system didn’t flow enough for their application. David stated that per square inch of exhaust tubing there is 115 CFM of flow. So plugging some numbers into the good ole TI-89….. ((3.14 * radius^2)*115[*2 for a dual exhaust system])/2.2 = Max hp supported with zero loss
A 2.75” (stock) single system is good for a 310hp engine with zero loss…
A 3” Single system is good for a 370hp engine with zero loss…
A 3.5” Single system is good for a 503hp engine with zero loss…
A 4” Single system is good for a 657hp engine with zero loss…
A 2.25” dual system is good for a 457hp engine with zero loss…
A 2.5” dual system is good for a 513hp engine with zero loss…
A 3” dual system is good for a 812hp engine with zero loss…
Now these numbers are assuming that everything else is set up perfectly. The muffler must flow as much as the open pipe or more to get zero loss at the listed hp levels. He also states that using a muffler with a larger inlet/outlet diameter than your exhaust pipe is a great way to get more out of a smaller diameter system since the muffler flow will be able to match the straight pipe flow. Now there are many other things to consider when designing an exhaust system but I figured this would give a great foundation to build on."
So let's clarify: you're comparing really crappy X-pipe systems to nearly perfect y-pipe systems?
Now, how is that a fair comparison?
And to clarify, yes, I am comparing TSP's duals to a burns stainless Y merge.
It doesn't have to be fair when you said: "No, the TD's outperform in EVERY CASE."
But hey, TSP is giving an affordable product to the masses that performs better than the average y-pipe setup, that's great for them. But don't get all confused and think that it's a GOOD system. It works better than most y-pipes and is affordable, and that is all. By comparison, the Burns stainless X system in that pic is going to run upwards of $1000. Most people don't want to spend that on their exhaust system, hence why there are options like TSP and Dr. Gas.
You're grasping at straws, here. A comparison use useless if you're comparing something high quality to something of poor quality.
I'll refer back to my FIRST post:
It's not my fault you won't read my posts. It's a level playing field. You're selectively quoting me AFTER the level playing field has already been established. That means it's your mistake, not mine.
From my SECOND post:
Again, my conditions from the very beginning were "equally well-made" where we are comparing the best of each. It's not my fault you can't read.
Read. The. Thread. First.
By the way, the Burn's merge can be copied for about $15...much cheaper than my Flowmaster merge in my y-pipe...so don't blame laziness for **** poor design.
Man, I miss the days when I was 18 and knew everything!
Have another wonderful day!
Galen
Galen
Perhaps you should invent a time machine so you can go back to the day you were 18. Being out of school for so long may have hampered your ability to learn
Q. What kind of gains can I expect with true duals?
A. If you have stock exhaust you will pick up around 30HP by going to duals with a set of headers. If you already have headers and a cat-back, don’t expect a big gain, but some are to be had if the catback is very.
Q. What are the benefits of duals?
A. Many people believe that duals sound much better than cat-backs. I personally believe that a good dual setup sounds better than any cat-back I have heard. That is the main benefit of duals since they yield similar power gains with y-pipes and duals take bit more work to get to fit.
I just wanted to point out your flawed exhaust theory. You were trying to say that more flow area = more power, which is misleading and inaccurate.
You can stop swinging from my nuts now man. Its kind of annoying. You even took the time to bold font your quote from my sticky
Wishful thinking on your part. And quite honestly, there is not much to swing from. LOL. You may return to your fantasy internet racing world now...
Well, you misunderstood me (or maybe I didn't phrase it quite right). And yes I realize that more flow doesn't always mean more power. But it does on an engine that requires more flow. You definitely are not talking to a newbie to the automotive world. I maybe a newbie to tech, but I guarantee you I've been around this kind of technology FAR longer than you have (you are only 25 and thats how I know).
Well then a big misunderstanding I guess.
So how long have you been around this technology since you know it all? Still havent heard what you drive or if its even modded.
I am back in my internet racing world, cant you read my title?
And I hate internet racing, thats why I don't give out too much info on the internet.
Congratulations?
<<<---Jordan
