True Duals Cost POWER!?!?!??
Neglecting wall thickness, the flow area of 2 x 2.5" pipes is about 9.81 in^2. The flow area of 1 x 3.5" single pipe is about 9.62 in^2 (almost as much as 2 x 2.5". The flow area of a single 4" pipe is 12.56 in^2 (almost 30% more flow area than 2 x 2.5" pipes). Which means that a single 4" pipe will BY FAR outflow 2 x 2.5" pipes. I swear there are some serious dipshits in this thread.
Your last statement only applies to one person, look at the name next to your post for the answer.
Galen
And yea, it probably doesn't run mid 11's, its probably slower otherwise you would have an 11 second club (or better) under your username. My bet is you have no clue what it runs because you've never been to the track. What a waste of money.
Oh look at my title now I run 9's. Douchebag, get a clue. You are really entertaining, you should chime in more in the street racing forum here.
https://ls1tech.com/forums/showthrea...t=#post3307293
You did trap 120 mph which tells me your probably spraying, but running 12s on a 150 shot, that simply is embarrassing. And your a mod also, obviously not a very credible one. Take your car to the track more often and study some fluid mechanics. Then we can all talk on the same level. But until then, I've got better things to do at the moment so,
Referenced from thread:
On a stock motor with spray, yeah I ran it bad then, but that was when i first started using spray so take it for what its worth.
Now im built motor, head, cam, and an even bigger shot of spray and i can drive it a lot better.
Keep amusing me. What an ***.
If youre ever out my way please bring some $$ and whatever youre driving
I find it sad that you're trying to create an uneven argument - as in a bad X-system compared to a nearly perfect y-system.
The entire time, I've been speaking of equally well-made systems. Why would anyone compare things any differently?'
Guess what: shorty headers will outperform longtubes if the longtubes have big cracks in them and crushed primaries. But well-made longtubes will outperform well-made shorties in every case, just like X-pipe TD's will outperform an equally well-made y-pipe system in every case.
As was said before, that was from 2005 you idiot. Also, you cant get the tag 9 secong club without proof.
And this is the whole problem, here. You are comparing some horribly made TD system that is not the norm to a well-made y-pipe system. How is that a level playing field? You're not being fair. The ENTIRE TIME, I have spoken of equally well-made systems, like the TSP kit and the Bassani kit. Both will make significant gains over any y-pipe and catback setup, as shown in the graph I posted.
Of course, this quote should give everyone else an insight into your knowledge of how to tell if a y-pipe is well designed.
It's not a show car, so I guess the welds will be fine. Nothing will perform better than a weld, and since I'd have to cut it all up anyway to change it, I may as well not even worry.
Have another nice day!
Galen
