Pulley?
Old Jul 17, 2003 | 04:56 PM
MaxedOutSS99's Avatar
Default Pulley?
I pretty much don't know anything about pulleys . What is the difference between underdrive and overdrive? wich is best. what do i need to get when buying one, such as bolts and a new belt obviously, anything else? if there is a thread about this already can somebody point me to it, thanks.
Old Jul 17, 2003 | 11:31 PM
Judd's Avatar
Default Re: Pulley?
If you are looking to gain HP or make your car faster, you want a underdrive pulley. Try a search on it.
Old Jul 18, 2003 | 12:46 AM
BergerMan's Avatar
Default Re: Pulley?
The underdrive pulley is installed on the crankshaft and reduces the amount of power required to run the accessories by reducing their rpm. One of the drawbacks of reduced accessory rpm is lack of alternator charging on cars with high powered stereos. This is where the overdrive alternator pulley comes into play. It will increase the rpm of the alternator and retain the stock charging capabilityof. Even if you have a mild stereo there is no need for the alternator overdrive pulley.
Old Jul 18, 2003 | 12:56 AM
ChazLS12002's Avatar
Default Re: Pulley?
I would personally, save up a little more money and get a Torque Converter. The pulleys won't add but 10 hp for $300 and the TC will liven up your A4
Old Jul 18, 2003 | 07:35 AM
Fast SS on TNT's Avatar
Default Re: Pulley?
See my sig....no pulley listed there. Its a waste of money me thinks!
Old Jul 18, 2003 | 10:03 AM
ApacheDrill's Avatar
Default Re: Pulley?
Not trying to Hijack the post.. but with all that said. Where does the harmonic balancer come into play?
Old Jul 18, 2003 | 06:36 PM
Default Re: Pulley?
thanks a lot guys, yea i think ill just save the money and buy a torque converter.
Old Sep 2, 2003 | 04:13 PM
Raben's Avatar
Default Re: Pulley?
I'd actually do both.
I did the TC first though. . .went with a TCI 3500 stall and so far I'm pleased with it. I'm fixing to install a ASP underdrive pulley though. See what it does for the car down the track. Not worried about the dyno numbers but moreso if it actually will shave off 1 tenth of a second off my times
Old Sep 2, 2003 | 04:31 PM
WJ SOM SS's Avatar
Default Re: Pulley?
ASP underdrive pulley is a good mod, It's usually always good for .1 second at the track. I've had a '99 M6 SS, and now a '02 A4 SS. ASP underdrives on both, .1 second in the 1/4 mile with both. It's a good quality piece, that's worth doing, in my opinion. But, on a A4 car, the stall converter is the best bang for the buck...but way more money than the underdrive pulley...Best wishes. WJ.
