LT Install Help
What, if any, can a person use to get the car high enough (without a lift) to do the install?? Thanks for the help in advance!!
Phillip
Just get the coil packs out of the way on the passenger side, pop out the dipstick tube, and go to town. (Make sure to disconnect the Battery since you are around the starter.
Piece of cake?... Wasnt the first time. Now... Yes.
-Find the biggest jack stands you can get. I used jackstand for suv's and it was high enough for my headers to slide in without needing blocks or anything like that.
-Remove the coil packs for more clearance to spark plugs and header bolts
-Now is a good time to change spark plugs and motor mounts while you are in there.
if youve got any friends with small hands, have them help out and buy them a beer. i ended up with at least 50 knicks and scratches on my hands and forearms unbolting the stock manifolds and bolting up the lts.
Now gotta tune that thing and get her runnin good again. I can already tell she's gonna be mean!!!
