Smooth Bellows cheap? Where to find?
Old Jul 18, 2003 | 12:44 AM
Inspector12's Avatar
TT-TECH Veteran
Default Smooth Bellows cheap? Where to find?
I remember seeing some one post up a place to get some knock off smooth bellows cheap I think they were like $10 for the one that looks like the SLP one except it just looked like rubber instead of having a shiney out side? I can't find the post I was wondering if any one knew what thier web address was ETC...? Any help would be appreciated>
Old Jul 18, 2003 | 10:54 AM
Carbon's Avatar
Default Re: Smooth Bellows cheap? Where to find?
ttt...
Old Jul 18, 2003 | 11:19 AM
bigMAC's Avatar
just buy a fernco 3" to 3" pipe ate home depot for like 5 dollars. Microwave it for like a little over a minute but not too long or it will melt. Just long enough to soften it up. Put it on with a little pressure and it will go on pretty easily. I did this and I haven't had any problems with it like some people have said. It works out ver well.
Old Jul 18, 2003 | 11:52 AM
CAT3's Avatar
Restricted User
I didnt nuke mine, but a little KY and she slide right on! No problems.
Old Jul 18, 2003 | 12:04 PM
WILWAXU's Avatar
The knock off's of the SLP (like the fernco) are stiff and can break or warp your lid.
Old Jul 18, 2003 | 01:36 PM
2001CamaroGuy's Avatar
home depot.....
I had mine on for over a year and a half with just the poly trans mount and no problems....
Old Jul 18, 2003 | 03:25 PM
smokin' joe 00 ss's Avatar
Fernco toilet bowl hose is the cheap way to go and if you want a cheap shifter too you can get a toilet plunger to match. Just kidding :p
Old Jul 18, 2003 | 04:03 PM
Screamin_Z's Avatar
3" to 3"??? why have I seen guys say "get the 3" to 4"???
Old Jul 18, 2003 | 04:17 PM
WICKED SS's Avatar
I got one from this plumbing company online but forgot the url, I got it for about $15 shipped and its not hella hard like those ferncos. I had one of those hard ones and sent that **** back!!!!
Old Jul 18, 2003 | 05:34 PM
unit213's Avatar
Administrator
Fernco works. No lid problems here for over a year.
Old Jul 18, 2003 | 07:29 PM
Danny2tek's Avatar
Inspector I think this is the one I posted a while back AirFlow Sys.
Old Jul 18, 2003 | 07:44 PM
Screamin_Z's Avatar
again, why have I seen people post about get a 3"-3" then others say get a 3"-4"??? I know the TB is bigger, but would a 3"-3" work???
Old Jul 18, 2003 | 07:52 PM
WICKED SS's Avatar
Thats where I got it.
And the only reason that I can think of people getting
3"- 4" is cause they have a 85mm maf like I do. Thats the size I got but the only problem I have is I dont know how much to cut. Anyone know the how much to cut?
Old Jul 18, 2003 | 10:00 PM
Casper9T9's Avatar
If you get the AFS get the 3.5" x 3.5" for the best fit. I ordered the 3.5" x 4" and it was loose on the TB, but it worked after being clamped down. I had to trim mine quite a bit.
Old Jul 18, 2003 | 10:39 PM
99 Black Bird T/A's Avatar
Baker Precision
http://www.bakerprecision.com/silicone.htm
May have to look around but you can find a nice 3 x 3 silicon hose.
I had a Frenco and hated the toilet hose look but each to their own.
Old Jul 18, 2003 | 10:53 PM
TT-TECH Veteran
Thanks that was what I was looking for Air flow systems. I appreciate everyone's input but just so everyone knows I also have the fernco on my car and do not have a problem with the function I just want it to look better and not like a pluming fixture no offence to each their own and it does work well no problems I just wanted it to look a little better. Thanks again everyone!
Old Jul 19, 2003 | 03:47 AM
WILWAXU's Avatar
Had the Airflow system piece. It's nearly as stiff as the fernco. We put it on a friends car.. now he can't keep the lid on it. Torque of the motor is is pulling the lid out of it's base.
I suggest going with Baker hose or the more expensive SLP. Or is a $14 part worth tearing up a $150 one?
FWW: Many fast cars out there still running the stocker Mine included
Old Jul 19, 2003 | 08:01 AM
TaTommyWS6's Avatar
Yeah, I tried the smooth bellows from Airflo Sys, and it would NOT fit right. I cut it nice, etc... Maybe with a WS6s raised air box, the angel is worse, because it was a really crappy fit. I am running the stocker now...
Tommy
Old Jul 19, 2003 | 09:13 AM
Danny2tek's Avatar
I had no problem trimming mine
