install headers top or bottom???
Old Mar 2, 2008 | 06:03 PM
boola1341's Avatar
Default install headers top or bottom???
i installed the driver side header from the bottom and it went in fine. Then i started on the passenger side.....problem. I got hung up on top so i tried the bottom....no can do. So i went back up top with the header and got it almost all the way but no. Which way did you'll go. I'm going to try it again tomorrow.
Old Mar 2, 2008 | 06:07 PM
blownws6_nc's Avatar
bottom.
Old Mar 2, 2008 | 06:11 PM
2_wacko's Avatar
Bottom.
Old Mar 2, 2008 | 06:14 PM
djfury05's Avatar
bottom, u'll figure it out
Old Mar 2, 2008 | 06:27 PM
DarkJuggalo's Avatar
bottom, just play with it a lil gotta turn it
Old Mar 2, 2008 | 06:29 PM
davered00ss's Avatar
Moderator
Bottom. Passenger side should just slide right up. Driver side is a little trickey. you need to face the header to the front of the car and rotate it into place.
Old Mar 2, 2008 | 06:33 PM
Pipelayaz's Avatar
Bottom.. make sure to remove the oil drain plug if you have KOOKS. Took me about 45 minutes to figure that one out...ahahahahah
Old Mar 2, 2008 | 07:01 PM
DaveX's Avatar
Bottom, make sure you have the car high enough so that you can get the header almost vertical and it should go right in.
Old Mar 2, 2008 | 07:30 PM
boola1341's Avatar
driver side didn't take no time. That damn passenger side is a.....Can't wait till morning to try it again. I think i need to jack the car up higher.....wish i had a garage or a shop.
Old Mar 2, 2008 | 07:58 PM
SYon22s's Avatar
yep, definately bottom
Old Mar 3, 2008 | 11:12 AM
boola1341's Avatar
finished putting my pacesetter headers on today. Started it up without connecting the ypipe and catback just to see what it sounds like....damn its loud. While the car was running i noticed a little smoke coming from both the headers. Didn't look like it was coming from the gaskets. Could this just be something thats on the headers burning off????
Old Mar 3, 2008 | 11:25 AM
Z Fury's Avatar
I've heard that is an oil that is used during the creation of the headers, but I'm not 100% confident in that answer.
Old Mar 3, 2008 | 11:41 AM
boola1341's Avatar
I'm going to let it run for a while to see if the smoking stops. I think i read the same thing somewhere about the oil.
Old Mar 3, 2008 | 11:53 AM
LS698ta's Avatar
its your oil from your hands and stuff
Old Mar 3, 2008 | 11:54 AM
LS698ta's Avatar
all the fingerprints and what not
Old Mar 3, 2008 | 12:02 PM
brad8266's Avatar
Bottom, my passenger side went in like it was lubed with Crisco, all i did was drop the starter I believe.
Old Mar 3, 2008 | 12:35 PM
RedRallyeZ's Avatar
+1
its just oil and crap from your hands and soot and stuff heating away
Old Mar 3, 2008 | 07:02 PM
boola1341's Avatar
the smoking has went away after several minutes. Now i need to get a tune. All i have is the predator and the LM-1. I'm going to post a question in the pcm section to see how far i can go with what i have to tune.
Old Mar 3, 2008 | 07:09 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If they were mac's you could go through the top.
Old Mar 3, 2008 | 07:14 PM
KCFormula's Avatar
I know.......I love how people on here give an answer without even seeing what type of headers. My Kooks went in from the top. Its the only way they would fit, even after taking 1/2 the engine bay apart.
