02 ls1 in a 98 camaro...
thanks
thanks for the help
chris
ive been spining my stock pistoned sotck rod bolts to a shift pt of 6850 and a red line at 7000 for about a year and a half dont listin to him they will be fine....also im still on the stock ls1 pump for the 02s there perfectly fine past 600hp im currently at 535 rwhp thew a danas60 vig3800 and a steel d/s on a bigassed cam only car with a 125shot and it hasnt fased it honestly i just think its a scam by the sponsers to get more money out of builds but dont get me wrong they do flow better but again it realy isnt nessasary allthough i would reccomend a light weight fly wheel it helps a whole lot in the rev stand point...
Well its been about a year and a half and ive changed the oil every 700 miles since ive owned it and its been about 3 years and 1.5yrs at the current power level personly everyone says that they are ticking time bombs well i say you all ither did something wrong or something because you underestimate the ls1 my oil goes in clean and comes out clean im talking it looks the same when i drane it its not black! oh and im going 6.7s at 103 in the eigth mile on a stock bottom end.
right now i cannot afford a ls6 intake, so i would just take the tubes off my block and put them on the new one? it has coolant tubes already sticking out the front. also take all sensors out of old motor and put in new one too? should be about it right?
not to call you out, but oil coming out black has nothing whatsoever to do with dirt and/or metal particles...its a chemical change that occurs in the oil from the heat cycling (yes even synthetic). if your oil is coming out exactly as it went in, your not driving the car or you have some sort of special oil we don't know about
