xs header question
Old Mar 15, 2008 | 02:47 PM
dutinsss's Avatar
Default xs header question
i'm about ready to install my xs headers and i know about how some of the guys that have them had to heat up and bend the drivers side collector down a bit to clear for the y-pipe. i plan on getting custom true duals so should i take my headers to get fixed before i install them or is that something a shop can do while the headers are installed and on the lift before they run the duals? also, does anybody know if the original xs y-pipe will fit to the new style xs headers that are coming out? just wondering if there woud be any reason why they wouldn't. thanks
Old Mar 15, 2008 | 02:49 PM
MjMaro's Avatar
There was a guy who posted not too long ago that he took his DS header to a muffler shop who fixed it up for him for around $50 or something like that. I'm not sure about the original y not working on the newly designed headers, but the guy who had his DS collector angle changed to fit better used the y-pipe without a problem.
Old Mar 22, 2008 | 09:56 AM
dutinsss's Avatar
well yesturday i went to two well know shops with very good reputations and a few other muffler shops in my town and they all said that it would be impossible to fix and if they heated it up and tried to bend it, because it was stainless steel, it would break. i'm going to try another place today but it's getting very frustrating because i cant install them until this gets done and NOBODY can help me out with it! i've got an oxyacetaline torch at home and i'm thinking about trying it myself, but i'd rather not because if it does break easily like their telling me it will, i'll be screwed. another thing, one of the shops told me i should take a hammer to my floorboard where the collector touches and beat it in a little bit and cut a few inchess off the collector so i can run pipes off of it. how does this sound? sorry for the length, thanks a lot.
Old Mar 22, 2008 | 10:26 AM
Hilton's Avatar
Tough Mudder
That's what I did. There's a thread on here somewhere about it, but here's the cliff's notes.
I cut off ~2", leaving enough for a band clamp to go on without the O2 bung getting in the way.
I created an "S" out of cut pieces of mandrel bent pipe and used that to bring down to the duals. I beat the floor up a little bit, and slid a screw clamp through a piece of heater hose, wrapping it around the exhaust where it was close to the floor.
Old Mar 22, 2008 | 10:52 AM
dutinsss's Avatar
thanks for the reply, its good to know that'll work if i have to. the only problem is that i was planning on slipping my ORY onto my headers until i could get it to a shop and get my true duals run and i doubt it'll fit after i cut the collectors and with it being angles up. does anybody think it would be risky trying to heat up and bend my collector down myself or should i do like hilton did and not risk cracking my collector?
Old Mar 22, 2008 | 10:38 PM
dutinsss's Avatar
ttt..
Old Mar 23, 2008 | 03:18 AM
Buckwheat's Avatar
You need to have an exhaust shop cut a narrow slit from the collector about three-quarters of the way around leaving only the top portion uncut. The cut will be immediatly behind the primaries. Then it will easily bend down and close up the gap. Weld the cut closed and your set. You will end up with the tip of the collector about 1.5" below it's original position and pointed in the same direction as the primaries. Only drawback is the weld will look kinda nasty. I paid 25 bucks to have mine done and it worked perfectly.
Old Mar 23, 2008 | 10:04 AM
dutinsss's Avatar
thats similar to what one guy told me to do but nobody around here wants to touch it because its stainless steel
Old Mar 23, 2008 | 11:06 AM
black2002ws6's Avatar
If you would like to ship it to me I'll have our shop fix it for you no charge. PM me if you would like to.
Old Mar 23, 2008 | 07:44 PM
INMY01TA's Avatar
Why does everyone cut the collectors up. Just need an s bend in the y pipe.
Old Mar 23, 2008 | 10:08 PM
If you put an s bend in the y then it hangs too low. If you just cut the collector and move it down a little the the y has plenty of ground clearance.
Old Mar 23, 2008 | 10:52 PM
bigfatls6's Avatar
I have a set of the xs headers also does this have to be done on all of them to be used? Mine also has the funny angle on the drivers side collector.
Old Mar 24, 2008 | 05:02 AM
Unertl42's Avatar
Mine are waiting for me at home. I can't wait to be stateside again
Old Mar 24, 2008 | 06:49 PM
dutinsss's Avatar
i'm going to try a few more places around me first, but if i have no luck with them either i'll let you know. thanks
Old Mar 28, 2008 | 04:26 PM
dutinsss's Avatar
well i went ahead and put them on and i dont think its going to be a problem. the passenger side went on perfect but i'm in the process of bolting up the drivers side and all the bolts went in execpt the very far back one. the bolt just wont start and when it does, its a little crooked. i think it may be that the hole in the headers is a tad off and not lining up exactly to the bolt hole in the head. do you think i should try drilling out the header bolt hole to make it fit? thanks
Old Mar 28, 2008 | 04:33 PM
Ericbigmac83's Avatar
Youre on the verge of stripping the threads inside the head, so be careful. i'd keep trying to get the bolt in and just make sure its lined up right. i doubt the manifold is off by enough to keep you from being able to properly line the bolt up. you can open it up a hair then just use a washer, but i dont think thats the problem.
Old Mar 28, 2008 | 04:36 PM
dutinsss's Avatar
yea i dont want to strip the threads but we've been trying at it for ever and its just not going in.
Old Mar 28, 2008 | 05:23 PM
Nope it won't hurt to drill the hole out a little bigger.
Old Mar 28, 2008 | 08:37 PM
RevGTO's Avatar
Pontiacerator
It's not a big deal. After I learned about this solution, some friends at a local shop did it to mine with the usual basic welding equipment. Sure, it's not pretty like the welds on the headers themselves, but it works.
Old Mar 28, 2008 | 08:39 PM
RevGTO's Avatar
Pontiacerator
I had that problem too. He's right - just open it up a little.
