Ls6 intake swap
If you don't plan on keeping EGR which many don't, then you will need a plate to block it off your exhaust manifolds and a tuner to get rid of the code.
it came out very clean too
oh and stingr when you do your intake swap i would pick up a set of knock sensors and go ahead and replace em, since there under your intake manifold. you dont want to get your intake on there and one of them go out.
it all depends if you want to modify the intake.... or modify your stock coolant tubes..... some people dont like chopping up the intake..... however you will never be able to see the bottom of the intake and it will not hurt the resale value of the intake...... if you ever switch your intake setup you are bound to get the market value for the intake with or without the ribs!!!!
just remember to carefully scrape the foam pads off your stock intake and glue them into the factory position on the ls6 intake.... this will keep debris out from between the block and intake
I chose to go with the crossover tubes for 2 reasons.
1. Thats the way they come on the vettes to why go hacking up a $350 part to save $40 so it can be how its supposed to.
2. Some also say that if you want to run nitrous it is better to have the crossover tubes as well.
Also as other said...replace the knock sensors and the wiring harness. The get corrosion and if your under there why not?
Another thing is when you take the bolts out...the last 4 (or last 2 i cant remember) will not come out all the way so some1 came up with the great idea to use clothespins to keep them up.
There is a huge post about a page or 2 back that has all this information.
