ASP Pulley with Katech tensioner walking??
Sorry for the newbie type question but with my cam swap last night I decided to put an ASP pulley on the car and as soon as I get on it hard it will walk halfway off the power steering and the tensioner pulley. So I put on a used Katech tensioner and it still does the same thing. Yes I verified the alignment of all the pulleys and the belt with a straight edge. It will not walk under normal driving or moderate throttle but every so many times I decide to get on it hard it will do it. Not everytime which does not make sense. So I figured I would ask some of you guys that might of had this problem. Also the tensioner pulley is my stock piece. I tried to get the pulley with the raised lip but then my belt is too short. Maybe I need 1 size larger belt and the use of the tensioner pulley with the higher lip?? Thanks for the help.
Yes I did everything to spec with the old bolt and then the new bolt to 37ft lbs + 140 degrees. I did use the special GM tool to install the pulley. This is my 6th cam swap in the last 10 years and I never had this issue with the stock pulley. It just started this morning since the asp was put on there last night.
