throttle body ported?
Old Mar 23, 2008 | 03:38 PM
b4c346's Avatar
Default throttle body ported?
hey guy's,looking to get my throttle body ported.took it off and can you tell me if this is ported already.i would appreciate it. thanks
Attached Thumbnails throttle body ported?-nozzle-engine-015.jpg   throttle body ported?-nozzle-engine-016.jpg
Old Mar 23, 2008 | 03:50 PM
billyb's Avatar
is there a flat spot before the blade or a lip from th eback side looking out
Old Mar 23, 2008 | 04:01 PM
b4c346's Avatar
if i run my finger towards the blade there is a noticable uphill slope about a 1/4 inch from the throttle blade.so if i run my finger from the back to the front should be smooth?there is a hump for sure
Old Mar 23, 2008 | 04:08 PM
BLACK2001SS's Avatar
It looks ported to me. Because it looks like thier is a edge under the bottom of the blade like they realy ported it out good and left the edge their so the blade still closed.
Old Mar 23, 2008 | 04:16 PM
b4c346's Avatar
i think it is already ported.looks too smooth to me and you can see like someone put a dremal with smooth sandpaper on it in some spots.damm was looking for another .10 for 75.00!
Old Mar 23, 2008 | 04:20 PM
yeah I rember when I did mine it had casting marks on it so if its smooth and shiy its been done.
Old Mar 23, 2008 | 04:27 PM
b4c346's Avatar
thanks black200ss appreciate it!
Old Mar 23, 2008 | 04:52 PM
Red99TA's Avatar
If that's ported then it's the worst port job I've ever seen. I say it's stock...coming from a guy that's ported at least 20 of these things.
Old Mar 23, 2008 | 05:36 PM
b4c346's Avatar
red99ta,think i sent you a pm if you were intrested in porting my throttle body.it's hard to tell if it was ported,but thats what i was looking for was a opinion from someone that could tell me if it was ported or not.appreciate your help
Old Mar 23, 2008 | 07:52 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yeah, that is definitely not ported. They took no material. Polished or cleaned up? Maybe, but certainly not ported.
Old Mar 24, 2008 | 07:59 AM
Bad Blue WS6's Avatar
Here's what a PnP'ed TB looks like...
Old Mar 24, 2008 | 08:19 AM
teke184's Avatar
here is an illistration of a ported TB.
the yellow parts are what is removed from in front of the blade all the way around the bore of the TB.
if that isn't there its been ported to some degree.
some porters smooth out the aproach to that "lip"...but a basic port job (took me 15mins on a lathe) just removes that lip.
Old Mar 24, 2008 | 09:59 AM
Those pics of the ported one look good and shiney but that dosent mean his hasnt been done the outer lip is thinner also. It looks nice but for the money if his been ported to some degree I dont think its worth it to get it ported.
I would use that money for a lid or an SSRA kit and if he has them allready save up for an intake or send it off to tpis and then get a 90 mm tb. Porting your TB is somthing you should do at home not pay to have it done, any one can port out a TB with a drimmel tool.
