Takin a break installing LT's, quick question
Old Apr 2, 2008 | 01:00 PM
greengoblinLS1's Avatar
Default Takin a break installing LT's, quick question
After getting started a nearly 2 days later than I wanted, I began installing my PS LT's. So far, removal of components on drivers side has been uneventful, other than noticing that the Air tube gasket was nearly non-existent.
My question while I take a break is this. After all the posts I read, I completely forgot about that damn metal "block" that protrudes out. I was within mm of getting the header to go right up and poof! There was that little block "tab".
So.....grind it down? cut it off? best course of action would be??
I appreciat the help
Old Apr 2, 2008 | 01:02 PM
tennz28's Avatar
grind it down, just enough to press the header through.
Old Apr 2, 2008 | 01:05 PM
tylerdj's Avatar
If it's getting in your way just grind it down. Some headers will clear it just fine, and some won't.
Old Apr 2, 2008 | 01:07 PM
lastcall190's Avatar
Grind it or get the car higher, everyone is different. Just a little more clearance and you might be able to work around it. Perfect example:
Did my PS LTs on my car when I first got them, had to cut the tab off. Did the SAME EXACT LTs (took 'em off my car and sold to a member, helped him put them on) on a 99 car. Tab was in the way. Jacked up a touch higher, wiggled around it, and they slid right up in. If you wanna cut, a sawzall makes very short work of it.
-J
Old Apr 2, 2008 | 01:14 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Grinding, or getting it up higher helps. with my LT's I removed the oil filter and drain plug with great success.
Old Apr 2, 2008 | 01:24 PM
farnoush's Avatar
I just chopped mine in half, took like 2 minutes.
Old Apr 2, 2008 | 01:41 PM
00cls1camaross's Avatar
grinded the **** out of mine, my car was a on a lift too so it was high enough...
Old Apr 2, 2008 | 01:54 PM
slow1999blackz28's Avatar
cut like an 1/8 to a 1/4 off the tab it comes off really easy, why worry about grinding.
Old Apr 2, 2008 | 02:01 PM
CAMAROZ28AQUINO's Avatar
mine pacesetters fit in fine, esp. the passenger side. But do what these guys said! try and wrestle it up there without marking ur headers up too bad first tho..
Old Apr 2, 2008 | 02:07 PM
andrew69_04's Avatar
my MAC's cleared the tab on the dr side but i had to wiggle around it. As for the passenger side......welll, lets not go there.
Old Apr 2, 2008 | 09:53 PM
GregWS6&z28's Avatar
macs are really easy
Old Apr 2, 2008 | 10:17 PM
Apollo0526's Avatar
ran into the same problem, went 2 clicks higher on the stands and it was np
Old Apr 2, 2008 | 11:06 PM
DarkJuggalo's Avatar
get the car up higher and try again, if not then i would say grind it
Old Apr 3, 2008 | 11:33 AM
senicalj4579's Avatar
I never had the "block problem" and I still dont know what it is lol. If its just a mm or so just grind it down.
Old Apr 3, 2008 | 12:06 PM
socmguy's Avatar
Restricted User
Use whatever you got. If you don't have a sawzall, grind.
Old Apr 3, 2008 | 02:37 PM
Default header made it in!, now some bolt questions, gasket, etc.
Got the little tab off - gotta love a sawzall. Header made it up in there after I cut that little S.O.B off. Is there a torque spec for PS LT's? The included instructions are really vague. Also, included was a "block off plate" for air and 3 gaskets. 2 same size, and 1 thats same size as that block off plate.? Any ideas on this??
Old Apr 3, 2008 | 02:50 PM
11ft-lbs first pass, 18ft-lbs 2nd pass. You probably will NOT get a torque wrench on all the bolts. It is important to torque from the inside of the engine outward. Meaning, of the 6 bolts, torque the middle two first, and move outward, alternating each side. The block off plates? I don't quite understand what you're saying...
-J
Old Apr 3, 2008 | 03:13 PM
Anybody?
Old Apr 3, 2008 | 03:14 PM
ta_06374's Avatar
With the Macs I just jacked up the motor.
Old Apr 3, 2008 | 03:15 PM
Thanks, the page wouldnt refresh, disregard the immediate above post that says "anybody". Thanks for the reply lastcall190, I am gonna post up a few pics in about 5 mins better describing the other thing I'm talking about.
