swapping a ls6 intake for a fast 92/92 whats all needed?
what all will i need to get this done at home? what all can i use that i already have there? i will be swapping out my ls6 intake & shaner 3 for a FAST 90/90 or 92/92 & was wondering what all i will need so i get it done right the first time in one shot at home with all the right parts.
do i need.............................................. .................................................
new lid with bigger opening,85 mm or what size do they make now?
stock maf work? or do i need larger?what size?
smooth bellows of any kind or size?
will the stock fuel rails work?
sensors for the old t-body swap on to the new 90 or 92?
please any info pointing me in the right direction!!!!!!!!!!!!!
oh yeah who has the best price on a new fast 90 or 92 set up?
thanx guys
thanx guys
You can use any regular aftermarket lid and the stock MAF. Running a larger size lid and MAF is possible, but not necessary. The stock accordian bellows fits over a 90mm as some claim, but it wouldn't come close to fitting over my 92mm throttle body without some heating and expanding. Stock fuel rails work fine.
Contact Vengeance for the manifold. You can get a well ported FAST 92mm shipped to you for just a couple dollars more than most other places that sell just a stock FAST with no shipping.
You need a 5mm allen wrench to install the intake. Also the same size fits the valley pan bolts. Intake gaskets are a must. Felpro has good ones you can get those at AdvanceAuto or AutoZone. Also need a fuel line tool-I made my own. You need a smaller allen wrench for the TPS and IAC sensors on the TB. I used the stock Accordian bellow on the 92mm had to take it off the MAF and stick my hand inside and stretch it over,but it fit. You need to silicon the MAP sensor in to your new intake or it will come out easily. Get some 1 inch long 1/4 fuel line split down the side to hold the back 4 bolts up. This will hold them out of the way to slide the intake out. Don't forget to lift the intake up before sliding forward or bye bye oil sending unit.
The following users liked this post:
Adjust It (04-12-2022)
