The pulley... is it really worth it?
Old Apr 8, 2008 | 06:40 PM
kratos2250's Avatar
Default The pulley... is it really worth it?
I have a 02 camaro tourquer v2, 3600 stall, and supporting bolt ons. Made 376/353 I really want to get a few more horses out of it before I get heads. Just wondering if the pulley is really worth it? Can I get 10 hp from it?
Old Apr 8, 2008 | 07:40 PM
Hell'sChariot's Avatar
A pulley will a good addition. It will add some good torque too. I have one that I'll be installing once my other parts get here.
Old Apr 8, 2008 | 07:47 PM
LS1crazy01's Avatar
It deffinatley helped my M6 out. It is pricey but in the end if you want every hp out of the motor then you need it. I have the SLP one.
Old Apr 8, 2008 | 07:50 PM
allngn_c5's Avatar
I went the ASP route and love the difference. Better gas mileage (especially when coupled with an ewp from meziere) quicker revving, and of course a few more hp.
Old Apr 8, 2008 | 08:09 PM
thebart455's Avatar
a pulley will help, the more mods you add the better it will help
Old Apr 8, 2008 | 08:41 PM
GuitsBoy's Avatar
The higher you spin the motor, the more youll gain from a pulley. I dont know about 10 RWHP, but certainly 5 is not out of the question. Its worthwhile.
Old Apr 8, 2008 | 09:52 PM
01ssreda4's Avatar
are the downs worth the 5 HP though??
Old Apr 8, 2008 | 09:56 PM
Detoxx03's Avatar
I have one and SLP one and would say its worth it
Old Apr 8, 2008 | 10:26 PM
INMY01TA's Avatar
What downs?
Old Apr 8, 2008 | 10:44 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by INMY01TA
What downs?
I am confused too.
Old Apr 8, 2008 | 10:47 PM
dshag's Avatar
the downs or concerns are overheating, not providing enough power to the electronics, etc...usually not a problem but can be...the main difference youll have with the pulley is revving a little faster due to less weight to spin...
Old Apr 8, 2008 | 10:49 PM
allngn_c5's Avatar
Originally Posted by orangeapeel
I am confused too.
I believe he's referring to some of the few people that may have had charging issues. I can honestly say I haven't had any issues. Now with that being said I am not running huge speakers, and amps like a lot of younger guys are. Those amps really draw the juice and if your battery is showing its age you need to understand you'll be replacing your battery more often when running a ud pully and big power sucking stereo amps. Those two items don't mix.
Old Apr 8, 2008 | 10:51 PM
allngn_c5's Avatar
Damn bro, you beat me to it. You must have posted while I was typing LOL
Old Apr 8, 2008 | 10:54 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Ok, that was what I thought he was saying. I was thinking Pro's and Con's. It was never a problem for me charging running an optima redtop and 2 MTX 5000 and an old school Rockford Fosgate punch a2 series amp. The headlights didn't even dim. Just don't get an over drive pulley along with it because you will have cross canceled your efforts. ( I know that sounds dumb, but working at a shop I have seen it all....and several times.)
Old Apr 8, 2008 | 10:59 PM
allngn_c5's Avatar
That's cool to hear bro. I'd have thought you'd be dimming pretty good with all that juice getting sucked. I'll bet your stuff bumped.
Old Apr 8, 2008 | 11:16 PM
dshag's Avatar
To add to my earlier comment about overheating, if you spend alot of time in stop and go traffic it can be a problem, meiser electric water pumps solve this and you could always pick up a water pump that pumps a little more then stock, if i remember right most aftermarket replacements claim about 15% increase at idle over stock and this is normally sufficient for any concerns or problems, you can always put an overdrive pulley on but that defeats the purpose...
Old Apr 8, 2008 | 11:17 PM
dshag's Avatar
LOL hate it when that happens
Old Apr 8, 2008 | 11:20 PM
allngn_c5's Avatar
You are correct about the MEZIERE ewp. Provides MAX coolant flow from idle. No issues with high rpm cooling either. Another reason for ewp is improved gas mileage, and quicker revving. Less resistance on the crank frees up some power by reducing parasitic loss.
Old Apr 9, 2008 | 06:38 AM
GuitsBoy's Avatar
Years ago before i had a DD, I have a 2K watt rms stereo that I buumped all the time in my camaro. Never had any issues with charging due to the 25% underdrive.
Old Apr 9, 2008 | 10:13 AM
An ewp would be nice, but im to much of a cheap bastard to spend $650 on a water pump. lol!
