help! AIR blockoff screw broke
Old May 1, 2008 | 06:59 AM
BlackTA519's Avatar
Default help! AIR blockoff screw broke
My car was making a tapping sound whenever i accelerated and i found out why. I had the AIR assembly removed from my car a few weeks ago and one of the screws for the AIR blockoff cover on the driver side broke.
What can I do to remove the screw? There's only about 1/32" of thread sticking out. If i cant remove the screw, is there any other way I can block off the AIR hole?
Old May 1, 2008 | 08:39 AM
95GreenZ28's Avatar
You can get an expanding plug from any auto parts store
Old May 1, 2008 | 09:39 AM
BlackTA519's Avatar
would the plug withstand the hot temperatures and pressures?
Old May 1, 2008 | 09:52 AM
95GreenZ28's Avatar
Oh yea hey work fine. I had one in mine before I got my ls6. You can also get a freeze plug and tap it in place and it puts a solid seal around it. I think the freeze plug size is 1-3/8" but I am not positive. Pretty sure though. And if you are concerned about it leaking you can put some rtv around it
Old May 1, 2008 | 04:56 PM
staringback05's Avatar
simpler idea....jb weld...back in the day when i had those manifolds...the screws never stayed in...so i jb welded and they never leaked...
Old May 1, 2008 | 10:04 PM
Eric95's Avatar
i think you're talking about the EGR where it connects to the top of the intake manifold..for the AIR block off, i would just weld it, then you dont have to worry about it..
Old May 2, 2008 | 09:10 AM
02silvaZ's Avatar
yep, that'll work, or take it to an exhaust shop and get it welded
Old May 2, 2008 | 01:01 PM
BlackTA519's Avatar
i did some research and the jb weld is resistant to temperatures up to 500 F. how hot can the engine manfiold get up to?
Old May 2, 2008 | 03:14 PM
Hilton's Avatar
Tough Mudder
Just drill it out and put a bolt through it.
