ls2 timing chain question
Old May 8, 2008 | 04:42 PM
smokinponcho73's Avatar
Default ls2 timing chain question
ok im getting a cam and was thinking about a new timing chain can i use the ls2 cahain with the ls1 gears?
thanks Brandon
Old May 8, 2008 | 04:56 PM
King Nothing's Avatar
yeah, i purchased a ls2 timing chain for my cam but haven't installed yet . . . but my buddy installed his hot cam w/ls2 timing chain and it works perfect
Old May 8, 2008 | 05:18 PM
did he use the ls1 gears? or buy the ls2 kit?
Old May 8, 2008 | 05:51 PM
LS1powerhouse02's Avatar
just buy the LS2 chain. It is made to go right on the existing sprokets. When you swap the chains out hold them side by side and look at how much beefier the LS2 is.
Old May 8, 2008 | 06:34 PM
Fb0dy0nly's Avatar
its bigger for sure and will fit all the old LS1 stuff, just did the swap on mine....
Old May 8, 2008 | 06:55 PM
Azrael's Avatar
The LS2 chain works with the stock LS1 gears, matter of fact it is the new standard replacement part for the LS1 chain.
John we still have to re-setup the install on your cam!
Old May 9, 2008 | 05:51 AM
yes we do!! i'm purchasing some 241 heads from a member on here today and then goin to have kyle at high performance P&P them next month . . . so i'll wait to put the new heads on with the cam at the same time, sound like a plan?
Old May 9, 2008 | 09:08 AM
Azrael's Avatar
Shoot we have an extra set of 241's (with PRC duals on them) as well. Sounds like a plan though!
Old May 9, 2008 | 09:36 AM
Boosted 99 TA's Avatar
i just did the ls2 chain when i did mine.
Old May 9, 2008 | 12:47 PM
ok i wish you would've told me this before today jack!!!!!
