wiring help
Old May 11, 2008 | 09:27 PM
lt1camaro95's Avatar
Default wiring help
I need to rewire the oil level sensor connector and dont know which one hooks to where. There are two wires, brown and black with white stripe. If the clip part of the plug is on top, which side does the two wires go? Oh yeah, this is for a 2002 TA.
Old May 12, 2008 | 09:14 AM
69LT1Bird's Avatar
The connector will have letters on it:
A = black/white (ground)
B = Brown (12 volt signal from PCM)
Old May 12, 2008 | 12:05 PM
thanks
Old May 12, 2008 | 07:36 PM
LS1MCSS's Avatar
Here is the schematic for it.
Old May 13, 2008 | 11:27 AM
Glad I didn't follow the first post.
Old May 13, 2008 | 11:46 AM
69LT1Bird's Avatar
don't do anything yet, my data is directly from the GM online manual. I gave you the pinouts for a 2002 Pontiac Firebird with a 5.7L. I PM'd LS1MCSS to find out his source of the schematic.
Old May 13, 2008 | 12:06 PM
69LT1Bird's Avatar
Go with the schematic in the above post #4. The actually 2002 F car schematic is not correct for this circuit.
Old May 13, 2008 | 01:11 PM
LS1MCSS's Avatar
I am going to check my spare harness tonight, to make sure the schematic is correct.
Old May 13, 2008 | 08:54 PM
It would be nice if the Hanes/Chilton guides would have wire colors marked on the schematics. Where are you all finding this stuff?
Old May 13, 2008 | 09:25 PM
Well on the oil level sensor, there is no A or B side. There is only clip up top. So which side is A/B?
