borla
Old Aug 9, 2003 | 12:13 AM
ben8520's Avatar
Default borla
which plate makes the most power or should i run it with no plate.
Old Aug 9, 2003 | 01:13 AM
DONAIMIAN's Avatar
Default Re: borla
It "FEELS" like it has more TQ when its capped off, but then when its capped off it sounds like stock if not quieter. Running it closed should cost that much hp becasue the muffler is basily straight through.
Old Aug 9, 2003 | 07:50 AM
redsscamaroboy's Avatar
Default Re: borla
I bought a used Borla set up and do not have any plates.
Where do you get these plates?
Dave
Old Aug 9, 2003 | 09:06 AM
StalkerLS1's Avatar
Default Re: borla
You have to contact Borla and order them. They'll sell you a set of plates no problem.
IMHO, getting the most torque down low with the block off plate will cause your top end power to suffer. I'm looking at buying a borla myself soon and was going to just run it wide open or possible a middle plate.
Old Aug 9, 2003 | 11:54 PM
ben8520's Avatar
Default Re: borla
i tried running it without a plate and the car is not as snappy i guess borla is right that the plate with the smallest hole makes the most power. I have 4.10 rear gears and i still feel like i lost low end without a plate
Old Aug 10, 2003 | 12:38 AM
Blk00WS6's Avatar
Default Re: borla
I'm running no plate and i do feel a loss at low rpm but it makes up for it in the top end.
Old Aug 12, 2003 | 09:43 PM
melbourne_ls1's Avatar
Default Re: borla
Get an electric cutout like the McCord Power Plate 2 (MPP2). It's only about $100 and works great! Lets you go from mild to wild in seconds.
Old Aug 13, 2003 | 03:04 AM
WS6 RULES's Avatar
Default Re: borla
My Borla works just like these posts have said. However I have never run without any plate. The largest hole plate is same diameter as pipe, so I use it for a sort of gasket. I didn't know Borla said smallest hole plate was best! It does feel that way but I wonder if there is a loss at top end. So I run the middle plate. The largest hole plate is just too loud for me, my ears are ringing when I get to work.
