View Poll Results: HP gain of custom ram air over STOCK setup...Track results tomorrow
0 gain no difference over stock
6.38%
1-5hp gain (.1-.5mph)
37.23%
6-10hp gain (.6-1mph)
21.28%
11-15hp gain (1.1-1.5mph)
19.15%
16-20hp gain (1.6-2.0mph)
7.45%
20+hp gain (2.0+mph)
8.51%
Voters: 94. You may not vote on this poll
MY RAM AIR VS. stock setup...How much HP Dif...TRACK RESULTS TOM.
Old 12-27-2009, 10:45 AM
  #101
chrs1313's Avatar
Originally Posted by shortdog
I'm interested in your larger ram air setup without the a/c condenser. BUT.. how does the air filter stay secure on that particular kit? From looking at the pics, I didn't see a filter tray it usually sits on. It also looks like the filter will fall right out of the bottom.
no the filter still uses the tray it is just cut on the back side where the ram air runs up it, i included a picture of my first version i had on my car...now i use better metal and a slight tweak on the measurements...dont mind the white caulk it dries clear...
so everything fits the same with just some minor cutting...lid base assembly fits in the same position and uses the same 4 10mm bolts to secure it, the filter and lid also work the same...
Chris
Attached Thumbnails MY RAM AIR VS. stock setup...How much HP Dif...TRACK RESULTS TOM.-filter-tray.jpg
Old 12-27-2009, 10:48 AM
  #102
chrs1313's Avatar
now available through Speed INC...they will give you a great deal on installing it too if you are local...
http://www.speedinc.com/cont.cfm?cid=C0000984
Old 12-27-2009, 08:26 PM
  #103
9 Second Club/Nitrous Mod
shortdog's Avatar
I'm assuming the metal lip that sits on the core support is wide enough to keep the filter secure? It looks like without the plastic support in the middle of the filter tray, the filter will fall right through the bottom due to the weight (K&N Filter).
Otherwise, great invention on your part. Do Speedinc have them in stock, or do you have to make them when the order is placed?
Old 12-27-2009, 10:01 PM
  #104
chrs1313's Avatar
The filter actually sits on the outer edge that middle support is not needed.
Also speed is going to be stocking some...
Old 12-27-2009, 11:11 PM
  #105
LS1-450's Avatar
Very nice Chris1313. I didn't know you had developed such an awesome ram air set-up.
Well done!
Old 12-28-2009, 07:09 AM
  #106
chrs1313's Avatar
Well done!
Yeah it started off with my original design I had on my car, then the demand for it rose so I tweaked the design for the better to what it is today…I am very happy with it, minimal modifying, light weight, good looks, excellent performance, and Speed Inc was kind enough to back it after they saw its performance on a few of their cars, including mine…Thanks
Old 12-28-2009, 12:20 PM
  #107
ds98formula's Avatar
Thats very cool that speed inc is backing and selling it now. Nice job Chris
Old 02-09-2010, 06:01 PM
  #108
chrs1313's Avatar
figured I would bump this for anyone new to the site or happened to miss it thread...cheap hp can be made with a ram air kit don't just pass it over...
Old 02-09-2010, 06:11 PM
  #109
lemons12's Avatar
I'm ordering at the end of this week (income)... How do we specify that we need to keep AC, or is that done through you?
Old 02-09-2010, 06:45 PM
  #110
chrs1313's Avatar
if you need an ac version just send me a pm and I will get one to you...speed inc carries the non ac version...
I would recommend the non ac version just for the gains and for the weight reduction...I have had a few people get the ac version and then a couple weeks later pull the ac and upgrade to the larger ram air...but if you are set on keeping the ac I can whip one up for you...
Old 02-09-2010, 06:46 PM
  #111
lemons12's Avatar
I will not remove the AC.
Old 02-09-2010, 08:00 PM
  #112
Formula_LS1's Avatar
Old 02-09-2010, 08:41 PM
  #113
lemons12's Avatar
Originally Posted by Formula_LS1
Going to guess you no longer have AC!
I will not be taking it off.. I have already had a car like that, this one will be staying full weight.... Plus some.
Old 02-09-2010, 08:53 PM
  #114
tspence45's Avatar
Hmmmmmmm. I'm considering ordering one sometime before my car's back together. I already have an SSRA. But, I'm keeping the A/C out with the new motor, and the bigger ducting should give me even more power.
Old 02-09-2010, 09:06 PM
  #115
edzsilverss's Avatar
Do you not pick up as much with the ac one? I'm in Texas and now way in hell we can go without an a/c. How much to ship one with a/c to Texas, 76065
Old 02-09-2010, 09:21 PM
  #116
Yep I used the AC maybe once or twice last summer (usually doesn't get too hot in Chicago), so I decided that I'd be better off without it.
I've had both and here are my results from the one WITH AC (taken from one of my older posts)...
"...this is with the DA corrected both before and after...I ran .178 seconds faster and 1.534 mph faster. Nothing else on the car was changed."
My car is SI, btw.
My car went into storage for the winter shortly after the one for non AC cars went on, but I'll have some new results in the spring.
Old 02-09-2010, 09:23 PM
  #117
chrs1313's Avatar
yes i would recommend it, i used to have a FTRA on my car then went to the non ac version (bigger ram air) and gained 1.2mph at the track...or around ~12rwhp(this was when i was SI also, so with head and cam the gain will be slightly more)...back to back weekends keeping DA in mind...
plus i made it so the bottom portion is removable so you dont have to worry about hitting it on curbs or on and off the trailer like the SSRA...
Old 02-09-2010, 09:27 PM
  #118
My car is SI, btw.
I can't open his build thread. How does the ac have anything to do with it other than what you gain from weight reduction and the ac belt not dragging? Does the ac stuff get in the way or something? I don't see how if it comes from under the car into the air box.
Old 02-09-2010, 09:40 PM
  #119
Basically, with the AC condenser out of the way, there is a lot more room. I've had both so here are some pictures I took of my car (notice the size difference of the opening where the air filter is)...
WITH AC...
WITHOUT AC...
Old 02-09-2010, 09:47 PM
  #120
WITH AC...
WITHOUT AC...
so you just push the radiator back some to create more room with the ac crap out of the way?
Quick Reply: MY RAM AIR VS. stock setup...How much HP Dif...TRACK RESULTS TOM.
